I would like to know if it is possible to display labels for a vector layer using the cartographic composer. I’m using G7 on linux. I also noticed in the GUI of d.vect the function “name of column to be displayed” (attrcolumn) is grayed up. Using the command line, labels are not displayed but no errors raise.
madi
Ing. Margherita Di Leo, Ph.D.
On Wed, Mar 28, 2012 at 1:15 PM, Margherita Di Leo
<dileomargherita@gmail.com> wrote:
You would need to prepare labels with v.label first, then add the
labels with the label keyword.
I'm using G7 on linux. I also noticed in
the GUI of d.vect the function "name of column to be displayed" (attrcolumn)
raise.
This is a bug in the GUI dialog. You can select an attrcolumn after
setting the layer option layer to some valid layer number, even though
the layer option llayer, not layer, is used to specify the layer for
attrcolumn.
Markus M
