[GRASS-dev] doc bug #411: quoting <> in html pages
re bug 411
http://wald.intevation.org/tracker/?func=detail&atid=207&aid=411&group_id=21
Any <> chars used in module option descriptions are broken when
converted into html docs.
Daniel pointed out that parser.c has print_escaped_for_xml() for this.
but....
lib/gis/parser.c G_usage_html()
if (opt->description) {
  fprintf(stdout, "<DD>");
  newbuf = G_str_replace(opt->description, "\n","<br>");
  if (newbuf) {
  print_escaped_for_xml(stdout, newbuf);
    G_free(newbuf);
  } else
  print_escaped_for_xml(stdout, opt->description);
  fprintf(stdout, "</DD>\n");
print_escaped_for_xml() reformats the <BR>s which were inserted by
G_str_replace() into "&lt;BR&gt;". :frowning:
any ideas? Use G_tokenize() with '\n' as the field sep?
Hamish
Hamish wrote:
re bug 411
but....
  if (newbuf) {
    G_free(newbuf);
  } else
Add e.g. "char *escape_xml(const char *)" which returns either its
argument or a dynamically-allocated copy with &<> replaced. Apply that
first, then apply G_str_replace() to the result, then print that.
I wouldn't worry about free()ing the result, as this will only be
applied to a relatively limited amount of data.
