I am trying to create a docker image with wxGUI.
After hours of attempts (since Alpine does not offer the wxPython
package, so it needs to be pip installed in the Dcokerfile) I got it
build:
https://hub.docker.com/r/neteler/docker-alpine-grass-gis-gui
# fetch image
docker pull neteler/docker-alpine-grass-gis-gui
# run image
docker run -i -t --rm -v $(pwd):/tmp -v /tmp/.X11-unix:/tmp/.X11-unix
-e uid=$(id -u) -e gid=$(id -g) -e DISPLAY=unix$DISPLAY --name grass77
neteler/docker-alpine-grass-gis-gui grass77 --gui
Starting GRASS GIS...
WARNING: GRASS GUI not found. Please check your installation.
Switching to text based interface mode.
Hit RETURN to continue.
As you see - no GUI while g.gui is there!?
# interactive test
neteler/docker-alpine-grass-gis-gui /bin/bash
bash-5.0# grass77 /tmp/grassdata/nc_spm_08_grass7/user1/
Cleaning up temporary files...
__________ ___ __________ _______________
/ ____/ __ \/ | / ___/ ___/ / ____/ _/ ___/
/ / __/ /_/ / /| | \__ \\_ \ / / __ / / \__ \
/ /_/ / _, _/ ___ |___/ /__/ / / /_/ // / ___/ /
\____/_/ |_/_/ |_/____/____/ \____/___//____/
Welcome to GRASS GIS 7.7.dev\
GRASS GIS homepage: https://grass.osgeo.org
This version running through: Bash Shell (/bin/bash)
Help is available with the command: g.manual -i
See the licence terms with: g.version -c
See citation options with: g.version -x
Start the GUI with: g.gui wxpython
When ready to quit enter: exit
GRASS 7.7.dev (nc_spm_08_grass7):/grassdb > g.gui
ERROR: Your installation doesn't include GUI, exiting.
GRASS 7.7.dev (nc_spm_08_grass7):/grassdb > ldd $(which g.gui)
/lib/ld-musl-x86_64.so.1 (0x7fcf65ef1000)
libgrass_gis.7.7.so => /usr/local/grass77/lib/libgrass_gis.7.7.so
(0x7fcf65e71000)
libc.musl-x86_64.so.1 => /lib/ld-musl-x86_64.so.1 (0x7fcf65ef1000)
libgrass_datetime.7.7.so =>
/usr/local/grass77/lib/libgrass_datetime.7.7.so (0x7fcf65e65000)
libz.so.1 => /lib/libz.so.1 (0x7fcf65c4e000)
libbz2.so.1 => /usr/lib/libbz2.so.1 (0x7fcf65c3f000)
libzstd.so.1 => /usr/lib/libzstd.so.1 (0x7fcf65b99000)
bash-5.0# python3
Python 3.7.3 (default, Apr 17 2019, 11:48:37)
[GCC 8.3.0] on linux
Type "help", "copyright", "credits" or "license" for more information.
import wx
Looks ok.
I suspect some missing lib on my Alpine image but have no idea which one.
Does anyone has an idea?
thanks,
