[GRASS-dev] Does it exist a fast way to know the type of raster without using r.info
The add-on r.zonal.classes uses r.info to check if the provided rasters are in CELL because r.stats require a CELL raster as input.
The problem is that for heavy raster, running r.info takes ages compared to r.stats and thus create a bottleneck.
I'm looking for another to get the info about the type of raster (CELL, FCELL,...) which will be much faster. Some of you have any idea ?
Thanks
Hi again,
I think I did something wrong and was trying to run r.info at the same time that the raster was overwriting.
I just make a new attempt and r.info runs fast, as expected.
Sorry to bother you guys.
You can consider this topic close.
Le 13/01/20 à 15:13, Taïs a écrit :
Thanks
