[GRASS-dev] Does m.cogo belong in the File menu?
Can't we move m.cogo to somewhere else, instead let it being under "File"? As per "m.proj is under <Map projections>", m.cogo could fit somewhere between the <Vector -> Generate...> (points?) related tools?
Nikos
