[GRASS-dev] Does SUN_ELEVATION in Landsat's MTL file mean zenith for i.topo.corr?
Sorry for cross-posting.
I would like a confirmation for the following, regarding i.topo.corr:
Is SUN_ELEVATION the requested zenith parameter (by i.topo.corr)?
So, given the entry "SUN_ELEVATION = 45.38304417" in the the metadata file
"LT51840322011266MOR00_MTL.txt", then, the production of an illumination model
requires "zenith=45.38304417".
Or is it "zenith = 90 - SUN_ELEVATION", thus it becomes
zenith = 90 - 45.38304417 = 44.616956
Thank you, Nikos
Hi Nikos,
generally zenith angle = 90 - SUN_ELEVATION ANGLE indeed.
Yann
Thank you, Nikos
grass-dev mailing list
grass-dev@lists.osgeo.org
Yann Chemin
Researcher@IWMI
Skype/FB: yann.chemin
Yann Chemin:
Hi Nikos,
Thank you for the confirmation Yann :slight_smile:
Best, Nikos
