On Fri, Sep 5, 2008 at 10:28 AM, Martin Landa <landa.martin@gmail.com> wrote:
2008/9/5 Martin Landa <landa.martin@gmail.com>:
2008/9/5 Markus Neteler <neteler@osgeo.org>:
OK. The problem is that
"vector: Vector_Library (GRASS Vector and Direct Graph Library)"
is no longer expanded as link. Someone just asked me if the
vector lib is not documented and I discovered that the link is
no longer generated at all. I just tried a fix but it isn't expanded...
it should be
<li>%vector: \ref Vector_Library (GRASS Vector and Direct Graph Library)
No, not resolved. The change residual indicated above turns
back every week. Apparently a bug in
include/Make/Doxygen.make
12 # generate docs as multiple HTML documents:
13 htmldocs: checkdoxygen cleandocs
14 # hack needed to get main page at beginning:
15 @mv $(DOXINPUT) $(DOXINPUT).org
16 @sed 's+/\*! \\page +/\*! \\mainpage +g'
$(DOXINPUT).org > $(DOXINPUT)
17 doxygen $(MODULE_TOPDIR)/include/Make/Doxyfile_arch_html
18 @mv $(DOXINPUT).org $(DOXINPUT)
19 @echo "HTML reference in directory ./html/index.html"
Maybe mv fails and it must be 'mv -f'? The cronjob runs under
my user login on xblade14 and mv is an alias to 'mv -v'. I don't
know if aliases are picked up by user cronjobs.
They aren't, nor is the user's environment from /etc/profile,
~/.bash_profile, etc.
In any case, aliases only work in shells where they are explicitly
defined (in practice, this means interactive shells which source
~/.bashrc). They aren't propagated to child processes (e.g. scripts,
make, etc).
On Sun, Dec 14, 2008 at 2:54 PM, Glynn Clements
make, etc).
Thanks, then there must be some magic elsewhere.
For now, I force the removal and retrieval of the lib/vector/vectorlib.dox
file to get rid of the left-over change.
Currently ok, we'll see next Sunday if the fix persists.
