I've just committed some changes to the layout of the driver code.
Specifically, the display/drivers/lib directory has been moved to
lib/driver, while the bulk of the PNG driver has been moved into a
separate library in lib/pngdriver.
It shouldn't have any impact from the perspective of either
application code or the user, but the changes to the layout (and the
corresponding changes to the Makefiles) are signficant enough that I
could have missed something which could cause compilation problems.
I would appreciate it if people could report successful compilations
after having updated to the new code, so that I can get an idea of
when it's had a reasonable amount of testing. I don't want to commit
the next phase (integration of libpngdriver with libraster) until any
problems with the latest changes have been ironed out.
Can we tag 6.1.0 before the next lot of changes are committed?
It would make a common basis for before/after tests.
