[GRASS-dev] elevation.dted from spearfish
elevation.dted@PERMANENT in spearfish has this problem:
(slightly old spearfish60..)
G63> g.region rast=elevation.dted
ERROR: Invalid region: Illegal n-s3 resolution value
G63> cat spearfish60/PERMANENT/cellhd/elevation.dted
proj: 1
zone: 13
north: 4927700
south: 4913700
east: 609000
west: 590000
cols: 190
rows: 140
#e-w resol: 100
#n-s resol: 100
format: 0
compressed: 0
what's with the commented res?
G63> r.info elevation.dted -s
nsres=100
ewres=100
looks ok.
I got this error in gis.m when trying to zoom to selected map:
Error:can't read "parts(n)": no such variable
    while executing
"MapCanvas::zoom_new $mon $parts(n) $parts(s) $parts(e) $parts(w) $parts(nsres) $parts(ewres)"
    (procedure "MapCanvas::zoom_gregion" line 11)
    invoked from within
"MapCanvas::zoom_gregion $mon [list "rast=$map"]"
    (procedure "MapCanvas::zoom_map" line 45)
    invoked from within
"MapCanvas::zoom_map $mon"
    invoked from within
".mapcan(1).mf.topf.tb0.mapzoom.zm invoke active"
    ("uplevel" body line 1)
    invoked from within
"uplevel #0 [list $w invoke active]"
    (procedure "tkMenuInvoke" line 47)
    invoked from within
"tkMenuInvoke .mapcan(1).mf.topf.tb0.mapzoom.zm 1
    (command bound to event)
Hamish
Hamish,
are you sure that you have the latest Spearfish package?
http://grass.itc.it/sampledata/spearfish60_history.txt
----- Spearfish 6.0 - 0.2 :
26 Jul 2006 [M. Sieczka]
- removed outdated file PERMANENT/TODO (consulted with the author,
  Helena Mitasova)
- uncomented 'e-w resol' and 'n-s resol' in
  PERMANENT/cellhd/elevation.dted (fixes bug #4879)
We are at
http://grass.itc.it/sampledata/spearfish_grass60data-0.3.tar.gz
now :slight_smile:
Hamish wrote on 10/30/2006 11:18 AM:
proj: 1
zone: 13
north: 4927700
south: 4913700
east: 609000
west: 590000
cols: 190
rows: 140
#e-w resol: 100
#n-s resol: 100
format: 0
compressed: 0
nsres=100
ewres=100
looks ok.
    while executing
    invoked from within
    invoked from within
    invoked from within
    invoked from within
    invoked from within
Hamish
grass-dev mailing list
grass-dev@grass.itc.it
> Hi,
  Helena Mitasova)
We are at
now :slight_smile:
ok, no problem then.
thanks,
Hamish
