[GRASS-dev] Empty record in gselect.Select
Hi devs,
For g.gui.rlisetup I need an empty record or an empty string in gselect.Select. I would like add a variable in the__init__ function to add automatically the empty record to the list.
Is there any other way how to assign an empty value to gselect.Select?
Ciao
Luca
On Tue, Nov 4, 2014 at 8:53 AM, Luca Delucchi <lucadeluge@gmail.com> wrote:
Hi devs,
Ciao
Luca
Hm, why would you need an empty record? Can't you just leave the field
empty? Could you maybe better describe what exactly you want to do?
Anna
grass-dev mailing list
grass-dev@lists.osgeo.org
