I just noticed that the default value in ./configure for SQLite support is “no”. Since sqlite is the default for GRASS 7 wouldn’t make sense to have it enabled by default?
For example, wxGUI does not even considers missing SQLite as a possibility. I’m not sure if it is right and if modules are more robust. However, to make compilation easier for (compilation) first time users, I suggest to change the default to “yes”.
I don’t know how to do it, configure(.in) is still mysterious for me.
Vaclav
./configure --help | grep sql
–with-sqlite support SQLite functionality (default: no)
On Thu, Jun 26, 2014 at 10:06 PM, Vaclav Petras <wenzeslaus@gmail.com> wrote:
"no". Since sqlite is the default for GRASS 7 wouldn't make sense to have it
enabled by default?
I'm not sure if it is right and if modules are more robust. However, to make
the default to "yes".
To me that sounds reasonable.
I don't know how to do it, configure(.in) is still mysterious for me.
Very easy:
- in "configure.in" line 253, take out the ", no"
- then run autoconf-2.13
- run configure ... to test
wrote:
> Hi,
is
have it
> enabled by default?
possibility.
make
change
OK, done in r60995
Very easy:
Thanks, this was really easy, but my understanding is still low.
After autoconf2.13, I tested with make distclean, configure and make.
Vaclav
http://trac.osgeo.org/grass/changeset/60995
