[GRASS-dev] encoding of manual pages
hallo,
manual pages displayed with g.manual do have wrong encoding, which does
not need to fit system encoding settings.
<meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1">
people, who are using iso-8859-2 or utf-8 will get unsuable character
encoding:
http://les-ejk.cz/tmp/Obrazovka-2.png
should be
http://les-ejk.cz/tmp/Obrazovka-3.png
because of the manual pages are generated while system compilation, I
would suggest:
    - generate english version of manual pages by default
    or
    - the script for manpage generation should set propper header based
      on system encoding
what do you thing?
jachym
Jachym Cepicky
e-mail: jachym.cepicky@centrum.cz
URL: http://les-ejk.cz
GPG: http://les-ejk.cz/gnupg_public_key/jachym_cepicky-gpg_public_key.asc
OFFICE:
GDF-Hannover
Mengendamm 16d
30177 Hannover
Germany
e-mail: cepicky@gdf-hannover.de
URL: http://gdf-hannover.de
Tel.: +49 511-39088507
encoding:
should be
would suggest:
    or
      on system encoding
what do you thing?
Generate English manual pages. All of the description.html files are
in English; it's only the portions which are auto-generated via
--html-description which will be localised.
This should be sufficient:
  diff -u -r1.9 include/Make/Html.make
  --- include/Make/Html.make 2 Jul 2006 20:28:59 -0000 1.9
  +++ include/Make/Html.make 27 Aug 2006 11:57:37 -0000
  @@ -92,7 +92,7 @@
     GISBASE=$(GISBASE) \
     PATH=$(GISBASE)/bin:$$PATH \
     $(LD_LIBRARY_PATH_VAR)="$(GISBASE)/lib:$($(LD_LIBRARY_PATH_VAR))" \
  - $(1) --html-description | grep -v '</body>\|</html>' > $(PGM).tmp.html ; true
  + LC_ALL=C $(1) --html-description | grep -v '</body>\|</html>' > $(PGM).tmp.html ; true
   # html rules for cmd commands
   htmlcmd: htmlcmd1 htmlgen
Alternatively, the build process could just generate an error if any
of the locale variables (LC_ALL, LC_*, LANG) are set (to something
other than "C" or "POSIX"). This would also eliminate the issue of
people including localised error messages when they report compilation
problems.
hallo,
  @@ -92,7 +92,7 @@
+1
IMHO the HTML documentation should be english, because of the
translation of help messages does not necessary be right.
could anybody fix this in cvs? I do not have access.
problems.
jachym
Jachym Cepicky
OFFICE:
GDF-Hannover
Mengendamm 16d
30177 Hannover
Germany
> @@ -92,7 +92,7 @@
+1
I've committed this.
