[GRASS-dev] env variable: GRASS_DEBUG_LEVEL
Dear devs,
reading the manual of G_debug, I found miss leading the documentation:
"Print debugging message if environment variable GRASS_DEBUG_LEVEL is
set to level equal or greater" [0]
So I try to set the environment variable with:
export GRASS_DEBUG_LEVEL=5
but it didn't work. Is It a bug?
Vaclav, tell me that I have to use: "g.gisenv set=DEBUG=0" instead.
Maybe we should improve the documentation string to make it more
clear. What do you think?
Best regards
Pietro
On 9 November 2013 17:34, Pietro Zambelli <peter.zamb@gmail.com> wrote:
Dear devs,
ciao Pietro,
I think no
+1 for more documentantion in the doce
There is somenthing here http://grass.osgeo.org/grass70/manuals/variables.html
Best regards
Pietro
ciao
Luca
http://gis.cri.fmach.it/delucchi/
www.lucadelu.org
