[GRASS-dev] Error compiling the latest grass7svn
I just encountered the following error while compiling the last svn up
of grass_trunk:
In file /usr/local/src/grass7-svn/grass_trunk/dist.x86_64-unknown-linux-gnu/include/grass/gprojects.h,
couldn't find ogr_srs_api.h
I turned ogr_srs_api.h to gdal/ogr_srs_api.h and it did pass the error
and compiled.
Pierre
Scientist
Landcare Research, New Zealand
On 08/06/11 05:01, Pierre Roudier wrote:
of grass_trunk:
and compiled.
using --with-gdal=[path/to/gdal-config] as a configure option should do the trick.
Moritz
Sorry, I did not include my ./configure line.
I do have the --with-gdal=[path/to/gdal-config] option right. I did
not changed my configure options, I used the usual ones, which
compiled successfully on svn the last 6 months.
Pierre
2011/6/8 Moritz Lennert <mlennert@club.worldonline.be>:
of grass_trunk:
In file
and compiled.
trick.
Moritz
Scientist
of grass_trunk:
When posting compilation errors, it helps if you post the compilation
command as well as the error message.
and compiled.
This looks like something has changed with your GDAL installation.
