Dear dev,
Markus N. noticed that the auto-completion of the MetaModule instances
(pygrass.modules.shortcuts [0]) is broken...
if you open inside a grass terminal a ipython shell or if you try the
integrated shell in GRASS GUI the simple code:
from grass.pygrass.modules.shortcuts import vector as v
v.->TAB
You will get an OSError exception.
Here an example using ipythoninside the grass terminal.
In [1]: from grass.pygrass.modules.shortcuts import vector as v
In [2]: v.OSError error(2): No such file or directory
Display all 125 possibilities? (y or n)
v.buffer v.db_connect v.edit
v.in_mapgen v.lrs_create v.net_flow
v.out_pov v.rectify v.to_rast
v.build v.db_dropcolumn v.external
v.in_ogr v.lrs_label v.net_iso
v.out_svg v.report v.to_rast3
v.build_all v.db_droprow v.external_out
v.in_region v.lrs_segment v.net_path
v.out_vtk v.sample v.transform
v.build_polylines v.db_droptable v.extract
v.in_sites v.lrs_where v.net_salesman
v.outlier v.segment v.type
v.category v.db_join v.extrude
v.in_sites_all v.mkgrid v.net_spanningtree
v.overlay v.select v.univar
v.centroids v.db_reconnect_all v.generalize
v.in_wfs v.neighbors v.net_steiner
v.pack v.split v.unpack
v.class v.db_renamecolumn v.hull
v.info v.net v.net_timetable
v.parallel v.support v.vect_stats
v.clean v.db_select v.in_ascii
v.kcv v.net_alloc v.net_visibility
v.patch v.surf_bspline v.vol_rst
v.colors v.db_univar v.in_db
v.kernel v.net_allpairs v.normal
v.perturb v.surf_idw v.voronoi
v.colors_out v.db_update v.in_dxf
v.krige v.net_bridge v.out_ascii
v.proj v.surf_rst v.what
v.convert v.delaunay v.in_e00
v.label v.net_centrality v.out_dxf
v.qcount v.timestamp v.what_rast
v.convert_all v.dissolve v.in_geonames
v.lidar_correction v.net_components v.out_gps
v.random v.to_3d v.what_rast3
v.db_addcolumn v.distance v.in_gns
v.lidar_edgedetection v.net_connectivity v.out_ogr
v.rast_stats v.to_db v.what_vect
v.db_addtable v.drape v.in_lines
v.lidar_growing v.net_distance v.out_postgis
v.reclass v.to_points
I'm not able to understand who is raising the exception and why...
I always believed that the auto-completion was provided by the __dir__
magic methods, but the __dir__ method in the Metaclass instance it
seems to work without problems:
In [2]: dir(v)
Out[2]:
[u'buffer',
u'build',
u'build_all',
u'build_polylines',
u'category',
u'what_rast',
u'what_rast3',
u'what_vect']
Someone has a deeper understanding on how the auto-complete works on
ipython/GRASS shell, Do you have any idea on where could be the
problem and how we could fix it?
Thanks
Pietro
[0] http://trac.osgeo.org/grass/browser/grass/trunk/lib/python/pygrass/modules/shortcuts.py
