Dear all,
I am using r.surf.nnbathy (on GRASS 7.4)
Using a projected location (meters) I obtain a result
Using lat/lon location I see the following error:
File
“/home/roberto/.grass7/addons/scripts/r.surf.nnbathy”, line
80, in
main()
File
74, in main
obj = Nnbathy_raster(options)
File “/home/roberto/.grass7/addons/etc/v.surf.nnbathy/nnba
thy.py”, line 107, in init
Nnbathy.init(self, options)
thy.py”, line 13, in init
self.region()
thy.py”, line 20, in region
reg_N = float(kv[‘north’])
ValueError: invalid literal for float(): 47:00:29.111155N
I think the error is due to the https://trac.osgeo.org/grass/browser/grass-addons/grass7/vector/v.surf.nnbathy/nnbathy.py file and in particular to the region() function
reg = grass.read_command(“g.region”, flags=‘p’)
kv = grass.parse_key_val(reg, sep=‘:’)
reg_W = float(kv[‘west’])
reg_S = float(kv[‘south’])
reg_E = float(kv[‘east’])
nsres = float(kv[‘nsres’])
ewres = float(kv[‘ewres’])
perhaps this can be a solution:
in_region = gscript.region()
reg_E=float(in_region[‘e’])
reg_W=float(in_region[‘w’])
reg_N=float(in_region[‘s’])
reg_S=float(in_region[‘s’])
nsres = float(in_region[‘nsres’])
ewres = float(in_region[‘ewres’])
If you agree I will do some test and I can update the add-on
Any suggestions?
Thanks in advanced for your help
R
