[GRASS-dev] error in datacatalog
I am developing an addon for grass gis. it can view,copy,rename,delete maps in different location and mapset.
It can now display maps in same location and different mapsets. but when i change location an error is occured using spearfish data
ERROR: Raster map streams@PERMANENT not found
http://trac.osgeo.org/grass/browser/grass-addons/gui/wxpython/data_catalog
Mohammed Rashad K.M
http://keralainfo.web4all.in/
+919496620801
Sounds great! The only limitation for cross-location copying/moving of
maps is that the projection just be the same.
ERROR: Raster map <streams@PERMANENT> not found
I am afraid that only debugging statements will tell you where the
path info gets lost.
Similar for the slow display problem which you reported.
a map is displayed on application directory map.png !!! when i switch between displays the map.png changes
but no map is displayed on mapwindow. strange!!
Mohammed Rashad K.M
+919496620801
