I noticed an error that exist only in the french version (I test it in English and German): in the dialog box when you choose a map in the selection list, the result should be “your_map@your_mapset”. But here it is “your_map@de carte : your_mapset”. the french translation of “mapset” is “jeux de carte”, so it looks like GRASS is translating and cutting the name a a variable instead of retrieving its value …
it make the dialog box totally unusable, unless you delete manually the wrong part in the map name !
does anyone know where the selection list is coded and if there is some string that could be in a .po file ? as it’s happening only in french, I thing the bug sould be located in a french .po file, but I wasn’t able to find it …
this bug doesn’t exist in the official 6.4.1 release, but appear in every branch now (6.4-svn, 6.5 and 7)!
cheers,
Sylvain
2011/10/11 Sylvain Maillard <sylvain.maillard@gmail.com>:
selection list, the result should be "your_map@your_mapset". But here it is
"your_map@de carte : your_mapset". the french translation of "mapset" is
"jeux de carte", so it looks like GRASS is translating and cutting the name
a a variable instead of retrieving its value ...
string that could be in a .po file ? as it's happening only in french, I
thing the bug sould be located in a french .po file, but I wasn't able to
find it ...
this bug doesn't exist in the official 6.4.1 release, but appear in every
hopefully fixed in r48738 (trunk) and r48739 (devbr6). Could you test it?
Martin
PS: It's better to fill bug-report [1], mails can become easily lost
[1] http://trac.osgeo.org/grass/newticket
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
you did it, now it’s working well!
I didn’t fill a bug report because I was thinking of a bug in a .po file that I can fix, but I promise to do it next time
thanks,
Sylvain
2011/10/11 Martin Landa <landa.martin@gmail.com>
find it …
Martin
PS: It’s better to fill bug-report [1], mails can become easily lost
you did it, now it's working well!
OK, backported to relbr64 (r48740). Martin
