[GRASS-dev] error in pygrass
when I work with GRASS GIS I got following error
“No module named pygrass.modules.shortcuts”
Help me to solve it
Thanks
Niroshan Sanjaya
P Save a Tree.Please consider the environment before printing this email
Hi Niroshan,
On Wed, Aug 27, 2014 at 11:43 AM, Niroshan Sanjaya <nsanj88@gmail.com> wrote:
"No module named pygrass.modules.shortcuts"
Can you provide a bit more of code or some more information about your
workflow? What do you do? are you programming in python? are you using
a shell or the gui?
I suspect that is missing grass, the following line is working on my pc:
from grass.pygrass.modules.shortcuts import raster as r
Pietro
Please keep the conversation on the mailing-list.
On Wed, Aug 27, 2014 at 12:00 PM, Niroshan Sanjaya <nsanj88@gmail.com> wrote:
Yes I do programming on GRASS python shell, then I tried with terminal then
I got the same error.
I used the following codes
from grass.pygrass.modules.shortcuts import imagery as i
I believe that you are using grass6.*, and unfortunately the pygrass
modules is available only on grass7.*
Let me know.
Pietro
oohh…!! I was using GRASS 7, when I checked it now it shows Version 6.4.3
Thank you very much I will reinstall 7
I believe that you are using grass6., and unfortunately the pygrass
Let me know.
Pietro
Niroshan Sanjaya
