Compiling grass65 (revision 36627) I got an error in v.in.dxf
compilation :
gcc
-I/home/vincent/grass65_devel/dist.x86_64-unknown-linux-gnu/include -I/usr/include/ -g -O2 -I/usr/local/include -DPACKAGE=\""grassmods"\" -I/home/vincent/grass65_devel/dist.x86_64-unknown-linux-gnu/include -o OBJ.x86_64-unknown-linux-gnu/write_vect.o -c write_vect.c
write_vect.c: Dans la fonction «get_field_cat» :
write_vect.c:125: erreur: «DXf_BUF_SIZE» undeclared (first use
in this function)
write_vect.c:125: erreur: (Each undeclared identifier is
reported only once
write_vect.c:125: erreur: for each function it appears in.)
make: *** [OBJ.x86_64-unknown-linux-gnu/write_vect.o] Erreur 1
May it be due to recent changes to write_vect.c ?
Yours,
Vincent
Same here. It is just a typo:
DXf_BUF_SIZE -> DXF_BUF_SIZE (capital F)
I don't have svn access to commit, but it's an easy fix
Vincent Bain wrote:
compilation :
gcc
in this function)
reported only once
Yours,
Vincent
grass-dev mailing list
grass-dev@lists.osgeo.org
On Wed, Apr 8, 2009 at 8:04 PM, Andrew Danner <adanner@cs.swarthmore.edu> wrote:
Fixed in SVN.
