[GRASS-dev] Error launching wxgui
I've encountered the following error launching the wxgui from Grass 6.5
using today's svn checkout:
(I get several screens worth of the following text)
<snip>
d': None}, 'boundaryOne': {'color': (0, 255, 0), 'enabled': True}, 'direction': {'color': (255, 0, 0), 'enabled': False}, 'point': {'color': (0, 0, 0), 'enabled': True}, 'area': {'color': (217, 255, 217), 'enabled': False}, 'vertex': {'color': (255, 20, 147), 'enabled': False}, 'boundaryNo': {'color': (126, 126, 126), 'enabled': True}, 'highlight': {'color': (255, 255, 0), 'enabled': None}, 'centroidOut': {'color': (165, 42, 42), 'enabled': True}, 'centroidIn': {'color': (0, 0, 255), 'enabled': True}, 'centroidDup': {'color': (156, 62, 206), 'enabled': True}, 'nodeTwo': {'color': (0, 86, 45), 'enabled': True}, 'nodeOne': {'color': (255, 0, 0), 'enabled': True}, 'boundaryTwo': {'color': (255, 135, 0), 'enabled': True}, 'line': {'color': (0, 0, 0), 'enabled': True}}, 'queryDangle': {'than-selection': 0, 'thresh': 0}, 'catBoundary': {'enabled': False}}, 'workspace': {'posManager': {'enabled': False}, 'posDisplay': {'enabled': False}}, 'modeler': {'action': {'color': {'disabled': (211, 211, 211, 255), 'running': (255, 0, 0), 'valid': (211, 211, 211), 'invalid': (255, 255, 255)}, 'width': {'default': 1, 'parameterized': 2}, 'size': {'width': 100, 'height': 50}}, 'data': {'color': {'raster': (215, 215, 248), 'vector': (248, 215, 215), 'raster3d': (215, 248, 215)}, 'size': {'width': 175, 'height': 50}}, 'loop': {'size': {'width': 175, 'height': 50}}}, 'advanced': {'iconTheme': {'type': 'grass'}, 'settingsFile': {'type': 'home'}}}
advanced settingsFile type home
<snip>
After all this finishes, the following message is printed:
WARNING: Nviz extension (3D view mode) disabled. Reason: No module named ogsf
  File "/usr/local/grass-6.5.svn/etc/wxpython/wxgui.py", line 85, in <module>
    import gui_modules.nviz_tools as nviz_tools
  File "/usr/local/grass-6.5.svn/etc/wxpython/gui_modules/nviz_tools.py", line 2861, in <module>
    class NvizPreferencesDialog(PreferencesBaseDialog):
NameError: name 'PreferencesBaseDialog' is not defined
~ Eric.
Eric Patton wrote:
Looks like Martin Landa is printing out the settings for debugging?
There is new print stuff as of r42689 in preferences.py
The Nviz warning should go away soon, Martin is busy with it for GSoC.
<snip>
<snip>
~ Eric.
grass-user mailing list
grass-user@lists.osgeo.org
from Grass 6.5 using today's svn checkout:
I don't know if it helps for this error or not, but I've temporarily
re-enabled building swig/python in the 6.5 development branch for now.
I get the feeling that we are fighting too many battles at the same time
& so leave it to Martin to decide when that is ready to be switched off.
It is somewhat expected that wxNviz & ctypes will be a bit unstable in
6.5 for the next small while.
regards,
Hamish
I need a working 6.5 for other bugs, so I fixed nviz_tools.py and
preferences.py in r42720 and r42721
The warning
is still there, but Martin is going to replace the cpp nviz version
with a python version, IIUC, so no worries there.
Markus M
regards,
Hamish
grass-dev mailing list
grass-dev@lists.osgeo.org
Why? wxGUI doesn't use anything from swig/python.
AFAICT, the problems with the nviz module are due to a partial
backport; nviz_tools.py imports the (ctypes-based, Python) wxgui
module while the other files import the (SWIG-based, binary)
grass6_wxnviz module.
2010/7/8 Markus Metz <markus.metz.giswork@googlemail.com>:
wxNviz in develbranch_6 requires backport of ctypes from trunk. Then
it will be fixed.
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
