Hi , I have run into an error using Grass 7.7 svn revision 73556; when I open g.gui and try to add a vector or raster map and display it, I encounter the following error:
File
“/usr/local/grass-7.7.svn/gui/wxpython/core/gthread.py”,
line 121, in OnDone
event.ondone(event)
File
“/usr/local/grass-7.7.svn/gui/wxpython/core/render.py”, line
468, in OnRenderDone
self.updateProgress.emit(layer=self.layer)
File "/usr/local/grass-7.7.svn/etc/python/grass/pydispatch
/signal.py", line 229, in emit
dispatcher.send(signal=self, *args, **kwargs)
/dispatcher.py", line 349, in send
**named
/robustapply.py", line 60, in robustApply
return receiver(*arguments, **named)
File
742, in ReportProgress
self.renderDone.emit()
**named
File
649, in OnRenderDone
raise GException(_(“Rendering failed: %s” % msg))
core.gcmd
GException
Rendering failed: Overlays multiple PPM image files.
Usage:
g.pnmcomp input=name[,name,…] [mask=name[,name,…]]
[opacity=value[,value,…]] output=name [output_mask=name]
width=value
height=value [bgcolor=name] [–overwrite] [–help]
[–verbose]
[–quiet] [–ui]
Flags:
Parameters:
input Name of input file(s)
mask Name of input mask file(s)
opacity Layer opacities
output Name for output file
output_mask Name for output mask file
width Image width
height Image height
bgcolor Background color
ERROR: g.pnmcomp: Sorry, ↔ is not a valid flag
ERROR: g.pnmcomp: Sorry, is not a valid flag
I am using the following software:
GRASS version: 7.7.svn
GRASS SVN revision: r73556
Build date: 2018-10-16
Build platform: x86_64-pc-linux-gnu
GDAL: 2.3.2
PROJ.4: 5.2.0
GEOS: 3.7.0
SQLite: 3.22.0
Python: 2.7.15rc1
wxPython: 3.0.2.0
Platform: Linux-4.15.0-36-generic-x86_64-with-LinuxMint-19-tara
There were no errors during compliation or make. Any help appreciated,
~ Eric
