[GRASS-dev] Error on a winGRASS installer - With some projections
Hi
this is "almost" a follow-up from the messages that me and Helmut exchanged a couple of weeks ago (http://lists.osgeo.org/pipermail/grass-dev/2010-November/052549.html ; http://lists.osgeo.org/pipermail/grass-dev/2010-November/052554.html ).
Ok I have successfully created my installer and I trid to run my Python scripts with the gdalwarp interface and it runs "fine. What I do is:
1- Check image projection system
2- If different from location, I use gdalwarp
3- then run r.in.gdal and import
Ok this runs just fine for UTM zones but, when I tried with EPSG3763 (ETRS89/Portugal TM06), a system that was inserted in PROJ4 in March, it is not working. I mean, r.in.gdal does not recognizes the system. I mean, gdalwarp reprojects my image (in this case from LATLON to EPSG3763) but, when it comes to r.in.gdal reads, that does not happen and I get the following errror:
In my WinGRASSOSGEO4W compilation it runs just fine and for other projections (e.g. UTM) it runs just fine. Does anyone as a tip about this?
PS- I created this installer based on osgeo4W and grass6.4. from Early September and GRASS-Installer.nsi; GRASS-Packager.bat from 2 weeks ago...
Thanks
Antonio
__________ Information from ESET NOD32 Antivirus, version of virus signature database 5601 (20101108) __________
The message was checked by ESET NOD32 Antivirus.
http://www.eset.com
I have just forgot to place the error that r.in.gdal gives me:
No projection name! Projection parameters likely to be meaningless.
Datum <unknown> not recognised by GRASS and no parameters found
ERROR: Projection of dataset does not appear to match current location.
Location PROJ_INFO is:
proj: tmerc
datum: etrs89
ellps: grs80
lat_0: 39.66825833333333
lon_0: -8.133108333333334
k: 1
x_0: 0
y_0: 0
towgs84: 0,0,0,0,0,0,0
no_defs: defined
Dataset PROJ_INFO is:
ellps: wgs84
ERROR: proj
You can use the -o flag to r.in.gdal to override this check and use the location definition for the dataset.
Consider generating a new location from the input dataset using the 'location' parameter.
António Rocha wrote:
Hi
Thanks
Antonio
http://www.eset.com
