[GRASS-dev] Error on a winGRASS installer
Hi Antonio,
ERROR 4: Unable to open EPSG support file gcs.csv.
Try setting the GDAL_DATA environment variable to point to
the
directory containing EPSG csv files.
ERROR 1: Translating source or target SRS failed:
some days ago I've added the GDAL_DATA variable to the nsis-installer script:
r44053 - grass/branches/releasebranch_6_4/mswindows
http://lists.osgeo.org/pipermail/grass-commit/2010-October/015000.html
r44054 - grass/branches/develbranch_6/mswindows
http://lists.osgeo.org/pipermail/grass-commit/2010-October/015001.html
r44055 - grass/trunk/mswindows
http://lists.osgeo.org/pipermail/grass-commit/2010-October/015002.html
please prepare the files for building the installer with a fresh svn-checkout
of GRASS-Packager.bat to be sure that all gdal files are included and build
the installer with a fresh svn-checkout of the nsis-script.
best regards
Helmut
___________________________________________________________
GRATIS! Movie-FLAT mit über 300 Videos.
Jetzt freischalten unter http://movieflat.web.de
(please keep it on the ML)
Hello Helmut
I was using source from early September. Do you think that was the problem?
please try a fresh svn-checkout or the source-snapshot from last Saturday, because the GDAL_DATA variable etc.
was added last week.
best regards
Helmut
Helmut Kudrnovsky wrote:
Hi Antonio,
the
best regards
Helmut
__________ Information from ESET NOD32 Antivirus, version of virus signature database 5585 (20101102) __________
The message was checked by ESET NOD32 Antivirus.
http://www.eset.com
WEB.DE DSL Doppel-Flat ab 19,99 €/mtl.! Jetzt auch mit
gratis Notebook-Flat! http://produkte.web.de/go/DSL_Doppel_Flatrate/2
Hello Helmut
Thank you so much for your help.. It worked. As far as I was able to test, all my scripts from OSGEO4W are working on this installer.
Thank you.
Just one last question: can I expect any problems by using mswindows from an earlier Snapshot and my source code/compiled from older version (early September 2010)?
Hello Helmut
best regards
Helmut
Hi Antonio,
the
best regards
Helmut
GRATIS! Movie-FLAT mit über 300 Videos. Jetzt freischalten unter http://movieflat.web.de
http://www.eset.com
WEB.DE DSL Doppel-Flat ab 19,99 €/mtl.! Jetzt auch mit gratis Notebook-Flat! http://produkte.web.de/go/DSL_Doppel_Flatrate/2
http://www.eset.com
http://www.eset.com
Hi Antonio,
Hello Helmut
Thank you.
great. maybe you can share some example of using gdalwarp in a script in
the wingrass-world to the wiki?
the correct setting of the PROJ_LIB, GDAL_DATA and GEOTIFF_CSV stuff for wingrass (which is
needed for proj4, cs2cs, gdal) is in the source since the end of october. so scripts using this
libraries in an earlier wingrass-installation maybe have problems. it's better to use actuall wingrass-versions.
Helmut
Hello Helmut
best regards
Helmut
Hi Antonio,
the
best regards
Helmut
http://www.eset.com
http://www.eset.com
http://www.eset.com
