Hi devs
I am trying to use v.distance in a Python script. However, I am getting the error
Module("v.distance", from=tmpout3, to=tmp_val, upload="to_attr",
column="x", to_column=column)
File "<ipython-input-138-da4ba6c2bb80>", line 1
SyntaxError: invalid syntax
If I run the same directly on the command-line it runs without errors.
v.distance from=testmap1 to=testmap2 upload=to_attr column=x to_column=lv
Is this because 'from' is a reserved word perhaps? If so, how do I use this in a Python script? Otherwise, any idea what I might be doing wrong?
On Fri, May 19, 2017 at 8:50 AM, Paulo van Breugel
<p.vanbreugel@gmail.com> wrote:
Hi devs
error
Try _from or from_ (I am not sure which one is the right one now).
Anna
grass-dev mailing list
grass-dev@lists.osgeo.org
https://lists.osgeo.org/mailman/listinfo/grass-dev
On 19 May 2017 at 15:50, Paulo van Breugel <p.vanbreugel@gmail.com> wrote:
Hi devs
Ciao Luca,
error
It could be, try adding underscore ( _ ) before or after the from (
_from or from_ I don't remember )
ciao
Luca
www.lucadelu.org
Hi Anna and Luca,
Hi devs
error
So the underscore the prefix or suffix function as an escape character?
It seems to work both if used with grass.script
import grass.script as gs
gs.run_command("v.distance", from_=tmpout3, to=tmp_val, upload="to_attr", column="x", to_column=column)
Both do not seem to work with Module
from grass.pygrass.modules import Module
Module("v.distance", from_=tmpout3, to=tmp_val, upload="to_attr", column="x", to_column=column)
Anna
