[GRASS-dev] error while comipiling GRASS SOURCE CODE IN Msys
  I'm setting up an environment on Windows using MSYS, im following the
material BUILD FROM SOURCE from the website
http://www.webalice.it/marco.pasetti/qgis+grass/BuildFromSource.html
      1) while giving "make" to the grass-6.3.0 ,i have got errors like
  make[2]: *** No rule to make target
`/usr/local/src/grass-6.3.0/dist.i686-pc-mingw32/lib/libgrass_vect.dll',
needed by `
/usr/local/src/grass-6.3.0/dist.i686-pc-mingw32/bin/v.parallel.exe'. Stop.
      plz reply me , , if this is an error ,
View this message in context: http://osgeo-org.1803224.n2.nabble.com/error-while-comipiling-GRASS-SOURCE-CODE-IN-Msys-tp5586640p5586640.html
Sent from the Grass - Dev mailing list archive at Nabble.com.
The page is completely outdated (Last Update: 15 July 2008). Please follow
the instructions here:
http://trac.osgeo.org/grass/wiki/CompileOnWindows
@Marco: please add a link to our new page, thanks.
hi markus
happy to see your reply to my mail
that link you mentioned leads to build and install of GRASS, but my ultimate
aim is to develop in QGIS can i link with that too , ,
thanking you
  sunil
View this message in context: http://osgeo-org.1803224.n2.nabble.com/error-while-comipiling-GRASS-SOURCE-CODE-IN-Msys-tp5586640p5587809.html
