Hi Everyone,
I encountered an error while installing GRASS GIS from source. When i run the make command i got the following error (see attached error.log)
GRASS GIS compilation log
Started compilation: Tue Dec 4 17:17:19 EAT 2012
Errors in:
/usr/local/src/grass_trunk/gui/wxpython/animation
/usr/local/src/grass_trunk/gui/wxpython/mapswipe
/usr/local/src/grass_trunk/gui/wxpython/gmodeler
/usr/local/src/grass_trunk/gui/wxpython/rlisetup
In case of errors please change into the directory with error and run ‘make’. If you get multiple errors, you need to deal with them in the order they
appear in the error log. If you get an error building a library, you will also get errors from anything which uses the library.
And as suggested I changed into the affected directories and run the make command again and the error listed below came up
File “/usr/local/src/grass_trunk/dist.i686-pc-linux-gnu/scripts/g.gui.animation”, line 50, in
from core.settings import UserSettings
File “/usr/local/src/grass_trunk/dist.i686-pc-linux-gnu/etc/gui/wxpython/core/settings.py”, line 27, in
from core import globalvar
File “/usr/local/src/grass_trunk/dist.i686-pc-linux-gnu/etc/gui/wxpython/core/globalvar.py”, line 75, in
import wx.lib.flatnotebook as FN
ImportError: No module named flatnotebook
make: *** [g.gui.animation.tmp.html] Error 1
While flatnotebook exists within my python modules i don’t understand why it is not being imported successfully. When i run { locate flatnotebook } command on my terminal i get:
/usr/lib/python2.7/dist-packages/wx-2.8-gtk2-unicode/wx/lib/flatnotebook.py
/usr/lib/python2.7/dist-packages/wx-2.8-gtk2-unicode/wx/lib/flatnotebook.pyc
/usr/lib/python2.7/dist-packages/wx-2.8-gtk2-unicode/wx/lib/agw/flatnotebook.py
/usr/lib/python2.7/dist-packages/wx-2.8-gtk2-unicode/wx/lib/agw/flatnotebook.pyc
Has anyone encountered the same compilation problem?
Thanks
Regards Erick
(attachments)
error.log (649 Bytes)
