[GRASS-dev] Errored: GRASS-GIS/grass-ci#1473 (master - fb899ae)
Build #1473 has errored.
15 minutes and 20 seconds
Anna Petrášová
fb899ae Changeset →
wxGUI/datacatalog: fix needed for Windows
git-svn-id: https://svn.osgeo.org/grass/grass/trunk@69218 15284696-431f-4ddb-bdfa-cd5b030d7da7
System message:
We are seeing build failures due to new sudo-enabled Precise and Trusty images. See more details here. Thank you for your enduring patience.
Want to know about upcoming build environment updates?
Would you like to stay up-to-date with the upcoming Travis CI build environment updates? We set up a mailing list for you! Sign up here.
Documentation about Travis CI
For help please join our IRC channel irc.freenode.net#travis.
Choose who receives these build notification emails in your configuration file.
Would you like to test your private code?
Travis CI for Private Projects could be your new best friend!
