[GRASS-dev] Errored: GRASS-GIS/grass-ci#1659 (master - 9088f49)
Build #1659 has errored.
28 minutes and 50 seconds
Markus Neteler
9088f49 Changeset →
config.guess + config.sub: updated from http://git.savannah.gnu.org/cgit/config.git/plain/
git-svn-id: https://svn.osgeo.org/grass/grass/trunk@69738 15284696-431f-4ddb-bdfa-cd5b030d7da7
System message:
Delayed builds on our OS X and container-based infrastructures for open source projects. You can follow the updates here. Thank you for your patience.
Want to know about upcoming build environment updates?
Would you like to stay up-to-date with the upcoming Travis CI build environment updates? We set up a mailing list for you! Sign up here.
Documentation about Travis CI
Need help? Mail support!
Choose who receives these build notification emails in your configuration file.
Would you like to test your private code?
Travis CI for Private Projects could be your new best friend!
