1 hour, 48 minutes, and 7 seconds |
Markus Metz |
r.texture: fix #3210, #2315, clean up code git-svn-id: https://svn.osgeo.org/grass/grass/trunk@69838 15284696-431f-4ddb-bdfa-cd5b030d7da7 |
System message:
sudo apt-get update fails on sudo enabled Trusty builds. We’re currently working on a hotfix, check this for more details and a workaround. Thank you
Want to know about upcoming build environment updates?
Would you like to stay up-to-date with the upcoming Travis CI build environment updates? We set up a mailing list for you! Sign up here.
Documentation about Travis CI Need help? Mail support! Choose who receives these build notification emails in your configuration file. |
Would you like to test your private code?
Travis CI for Private Projects could be your new best friend!
