[GRASS-dev] Errored: GRASS-GIS/grass-ci#225 (master - a69e8aa)
Build #225 has errored.
13 minutes and 1 second
Václav Petráš
a69e8aa Changeset →
no G2C necessary for la.h
This finishes incomplete r54193 and is necessary after r66101.
git-svn-id: https://svn.osgeo.org/grass/grass/trunk@66103 15284696-431f-4ddb-bdfa-cd5b030d7da7
Want to know about upcoming build environment updates?
Would you like to stay up-to-date with the upcoming Travis CI build environment updates? We set up a mailing list for you! Sign up here.
Documentation about Travis CI
For help please join our IRC channel irc.freenode.net#travis.
Choose who receives these build notification emails in your configuration file.
Would you like to test your private code?
Travis Pro could be your new best friend!
Travis CI is powered by
This seems like an issue with connection between Travis and package archives. See the error messages from Travis below. It complies fine for me with and without LAPACK and BLAS.
Vaclav
Err http://ppa.launchpad.net/ubuntugis/ppa/ubuntu/ precise/main libspatialite5 amd64 4.1.0-2~precise1
Unable to connect to ppa.launchpad.net:http:
Err http://ppa.launchpad.net/ubuntugis/ppa/ubuntu/ precise/main libproj-dev amd64 4.8.0-3~precise2
Fetched 38.0 MB in 23s (1,625 kB/s)
Failed to fetch http://ppa.launchpad.net/ubuntugis/ppa/ubuntu/pool/main/s/spatialite/libspatialite5_4.1.0-2~precise1_amd64.deb Unable to connect to ppa.launchpad.net:http:
Failed to fetch http://ppa.launchpad.net/ubuntugis/ppa/ubuntu/pool/main/p/proj/libproj-dev_4.8.0-3~precise2_amd64.deb Unable to connect to ppa.launchpad.net:http:
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
The command “sudo apt-get install --no-install-recommends autoconf2.13 autotools-dev debhelper fakeroot flex bison libcairo2-dev libfftw3-dev libfreetype6-dev libgdal-dev libgeos-dev libglu1-mesa-dev libjpeg-dev libpng-dev libtiff-dev libmysqlclient-dev libncurses5-dev libpq-dev libproj-dev proj-bin libreadline-dev libsqlite3-dev libwxgtk2.8-dev libxmu-dev python python-wxgtk2.8 python-dev unixodbc-dev libnetcdf-dev netcdf-bin dpatch libblas-dev liblapack-dev python-numpy” failed and exited with 100 during .
Your build has been stopped.
On Fri, Sep 4, 2015 at 6:01 PM, Travis CI <builds@travis-ci.org> wrote:
GRASS-GIS / grass-ci (master)
Václav Petráš a69e8aa Changeset →
