[GRASS-dev] errors compiling nviz in GRASS 7
First, Markus’ fix made GRASS 7 configure properly too.
But when I went to compile it, I hit errors with nviz. Some of these are the new code, but ./lib/niviz won’t compile either. I don’t know if this is a minor compilation glitch or a bug. I’ve included the output below.
For the record, I’m on a Mac OS X 10.5. If this is bug-worthy, I’ll go ahead and put it in Trac too.
Michael
C. Michael Barton, Professor of Anthropology
Director of Graduate Studies
Arizona State University
Phone: 480-965-6262
Fax: 480-965-7671
Started compilation: Sun Jul 6 12:59:02 MST 2008
Errors in:
/Users/cmbarton/grass_dev/grass7_src/lib/nviz
/Users/cmbarton/grass_dev/grass7_src/gui/wxpython/vdigit
/Users/cmbarton/grass_dev/grass7_src/gui/wxpython/nviz
/Users/cmbarton/grass_dev/grass7_src/visualization/nviz2/cmd
In case of errors please change into the directory with error and run ‘make’.
If you get multiple errors, you need to deal with them in the order they
appear in the error log. If you get an error building a library, you will
also get errors from anything which uses the library.
Finished compilation: Sun Jul 6 13:06:30 MST 2008
make: *** [default] Error 1
cmb-MBP-2:grass7_src cmbarton$ cd /Users/cmbarton/grass_dev/grass7_src/lib/nviz
cmb-MBP-2:nviz cmbarton$
cmb-MBP-2:nviz cmbarton$ make
gcc -I/Users/cmbarton/grass_dev/grass7_src/dist.i386-apple-darwin9.4.0/include -arch i386 -Os -fno-common -DPACKAGE="“grasslibs”" -I/Users/cmbarton/grass_dev/grass7_src/dist.i386-apple-darwin9.4.0/include -I/Library/Frameworks/UnixImageIO.framework/unix/include -I/Library/Frameworks/GDAL.framework/Versions/1.5/Headers -DPACKAGE="“grasslibs”" -I/Users/cmbarton/grass_dev/grass7_src/dist.i386-apple-darwin9.4.0/include -o OBJ.i386-apple-darwin9.4.0/change_view.o -c change_view.c
In file included from /Users/cmbarton/grass_dev/grass7_src/dist.i386-apple-darwin9.4.0/include/grass/nviz.h:5,
from change_view.c:20:
/Users/cmbarton/grass_dev/grass7_src/dist.i386-apple-darwin9.4.0/include/grass/gstypes.h:13:19: error: GL/gl.h: No such file or directory
In file included from /Users/cmbarton/grass_dev/grass7_src/dist.i386-apple-darwin9.4.0/include/grass/gstypes.h:336,
/Users/cmbarton/grass_dev/grass7_src/dist.i386-apple-darwin9.4.0/include/grass/ogsf_proto.h:198: warning: parameter names (without types) in function declaration
/Users/cmbarton/grass_dev/grass7_src/dist.i386-apple-darwin9.4.0/include/grass/ogsf_proto.h:199: error: syntax error before ‘GLuint’
/Users/cmbarton/grass_dev/grass7_src/dist.i386-apple-darwin9.4.0/include/grass/ogsf_proto.h:455: error: syntax error before ‘gsd_set_font’
/Users/cmbarton/grass_dev/grass7_src/dist.i386-apple-darwin9.4.0/include/grass/ogsf_proto.h:455: warning: data definition has no type or storage class
/Users/cmbarton/grass_dev/grass7_src/dist.i386-apple-darwin9.4.0/include/grass/ogsf_proto.h:458: error: syntax error before ‘float’
/Users/cmbarton/grass_dev/grass7_src/dist.i386-apple-darwin9.4.0/include/grass/ogsf_proto.h:472: error: syntax error before ‘GLuint’
/Users/cmbarton/grass_dev/grass7_src/dist.i386-apple-darwin9.4.0/include/grass/ogsf_proto.h:492: error: syntax error before ‘GLuint’
/Users/cmbarton/grass_dev/grass7_src/dist.i386-apple-darwin9.4.0/include/grass/ogsf_proto.h:496: error: syntax error before ‘GLuint’
/Users/cmbarton/grass_dev/grass7_src/dist.i386-apple-darwin9.4.0/include/grass/ogsf_proto.h:554: error: syntax error before ‘int’
/Users/cmbarton/grass_dev/grass7_src/dist.i386-apple-darwin9.4.0/include/grass/ogsf_proto.h:746: error: syntax error before ‘gsd_put_legend’
/Users/cmbarton/grass_dev/grass7_src/dist.i386-apple-darwin9.4.0/include/grass/ogsf_proto.h:746: error: syntax error before ‘GLuint’
/Users/cmbarton/grass_dev/grass7_src/dist.i386-apple-darwin9.4.0/include/grass/ogsf_proto.h:746: warning: data definition has no type or storage class
/Users/cmbarton/grass_dev/grass7_src/dist.i386-apple-darwin9.4.0/include/grass/ogsf_proto.h:747: warning: parameter names (without types) in function declaration
In file included from change_view.c:20:
/Users/cmbarton/grass_dev/grass7_src/dist.i386-apple-darwin9.4.0/include/grass/nviz.h:24:22: error: GL/glx.h: No such file or directory
/Users/cmbarton/grass_dev/grass7_src/dist.i386-apple-darwin9.4.0/include/grass/nviz.h:113: error: syntax error before ‘GLXContext’
/Users/cmbarton/grass_dev/grass7_src/dist.i386-apple-darwin9.4.0/include/grass/nviz.h:113: warning: no semicolon at end of struct or union
/Users/cmbarton/grass_dev/grass7_src/dist.i386-apple-darwin9.4.0/include/grass/nviz.h:115: error: syntax error before ‘windowId’
/Users/cmbarton/grass_dev/grass7_src/dist.i386-apple-darwin9.4.0/include/grass/nviz.h:115: warning: data definition has no type or storage class
make: *** [OBJ.i386-apple-darwin9.4.0/change_view.o] Error 1
cmb-MBP-2:cmd cmbarton$ cd /Users/cmbarton/grass_dev/grass7_src/gui/wxpython/nviz
c++ -I/Users/cmbarton/grass_dev/grass7_src/dist.i386-apple-darwin9.4.0/include -arch i386 -Os -fno-common -I/Library/Frameworks/GDAL.framework/Versions/1.5/Headers -I/Library/Frameworks/Python.framework/Versions/2.5/include/python2.5 -I/Library/Frameworks/Python.framework/Versions/2.5/include/python2.5 -arch ppc -arch i386 -isysroot /Developer/SDKs/MacOSX10.4u.sdk -fno-strict-aliasing -Wno-long-double -no-cpp-precomp -mno-fused-madd -fno-common -dynamic -DNDEBUG -g -O3 -I/usr/local/lib/wxPython-unicode-2.8.8.0/lib/wx/include/mac-unicode-debug-2.8 -I/usr/local/lib/wxPython-unicode-2.8.8.0/include/wx-2.8 -D_FILE_OFFSET_BITS=64 -D_LARGE_FILES -D__WXDEBUG__ -D__WXMAC__ -I/usr/X11/include -DPACKAGE="“grasslibs”" -I/Users/cmbarton/grass_dev/grass7_src/dist.i386-apple-darwin9.4.0/include -o OBJ.i386-apple-darwin9.4.0/change_view.o -c change_view.cpp
/Developer/SDKs/MacOSX10.4u.sdk/System/Library/Frameworks/CoreServices.framework/Frameworks/CarbonCore.framework/Headers/MachineExceptions.h:245: error: declaration does not declare anything
/Developer/SDKs/MacOSX10.4u.sdk/System/Library/Frameworks/ApplicationServices.framework/Frameworks/ColorSync.framework/Headers/CMICCProfile.h:389: error: expected unqualified-id before numeric constant
/Developer/SDKs/MacOSX10.4u.sdk/System/Library/Frameworks/ApplicationServices.framework/Frameworks/ColorSync.framework/Headers/CMICCProfile.h:390: error: expected unqualified-id before numeric constant
/Developer/SDKs/MacOSX10.4u.sdk/System/Library/Frameworks/ApplicationServices.framework/Frameworks/ColorSync.framework/Headers/CMICCProfile.h:391: error: expected unqualified-id before numeric constant
/Developer/SDKs/MacOSX10.4u.sdk/System/Library/Frameworks/ApplicationServices.framework/Frameworks/ColorSync.framework/Headers/CMICCProfile.h:397: error: expected unqualified-id before numeric constant
/Developer/SDKs/MacOSX10.4u.sdk/System/Library/Frameworks/ApplicationServices.framework/Frameworks/ColorSync.framework/Headers/CMICCProfile.h:398: error: expected unqualified-id before numeric constant
/Developer/SDKs/MacOSX10.4u.sdk/System/Library/Frameworks/ApplicationServices.framework/Frameworks/ColorSync.framework/Headers/CMICCProfile.h:399: error: expected unqualified-id before numeric constant
/Developer/SDKs/MacOSX10.4u.sdk/System/Library/Frameworks/ApplicationServices.framework/Frameworks/QD.framework/Headers/Quickdraw.h:273: error: using typedef-name ‘Cursor’ after ‘struct’
/usr/X11/include/X11/X.h:108: error: ‘Cursor’ has a previous declaration here
/Developer/SDKs/MacOSX10.4u.sdk/System/Library/Frameworks/ApplicationServices.framework/Frameworks/QD.framework/Headers/Quickdraw.h:278: error: using typedef-name ‘Cursor’ after ‘struct’
/Developer/SDKs/MacOSX10.4u.sdk/System/Library/Frameworks/ApplicationServices.framework/Frameworks/QD.framework/Headers/Quickdraw.h:278: error: invalid type in declaration before ‘;’ token
/Developer/SDKs/MacOSX10.4u.sdk/System/Library/Frameworks/ApplicationServices.framework/Frameworks/QD.framework/Headers/Quickdraw.h:278: error: conflicting declaration ‘typedef int Cursor’
/usr/X11/include/X11/X.h:108: error: ‘Cursor’ has a previous declaration as ‘typedef XID Cursor’
lipo: can’t figure out the architecture type of: /var/folders/AK/AKpYwDw1EoWI+fFF02nvRk+++TI/-Tmp-//cc8d1b5h.out
cd /Users/cmbarton/grass_dev/grass7_src/visualization/nviz2/cmd
cmb-MBP-2:cmd cmbarton$ make
make: *** No rule to make target /Users/cmbarton/grass_dev/grass7_src/dist.i386-apple-darwin9.4.0/lib/libgrass_nviz.dylib', needed by /Users/cmbarton/grass_dev/grass7_src/dist.i386-apple-darwin9.4.0/bin/nviz_cmd’. Stop.
Michael,
On Sun, Jul 6, 2008 at 10:16 PM, Michael Barton <michael.barton@asu.edu> wrote:
First, Markus' fix made GRASS 7 configure properly too.
(for the record): it was actually Glynn's fix.
I'm on a Mac OS X 10.5. If this is bug-worthy, I'll go ahead
No need I think.
Errors in:
Do you lack some devel package? On My Mandriva box, it is in
rpm -qf /usr/include/GL/gl.h
lib64mesagl1-devel-7.0.1-10mdv2008.0
... /Developer/SDKs/MacOSX10.4u.sdk/System/Library/Frameworks/CoreServices.framework/Frameworks/CarbonCore.framework/Headers/MachineExceptions.h:245:
error: conflicting declaration 'typedef int Cursor'
/usr/X11/include/X11/X.h:108: error: 'Cursor' has a previous declaration as
'typedef XID Cursor'
lipo: can't figure out the architecture type of:
Looks like a Mac specific error to me.
`/Users/cmbarton/grass_dev/grass7_src/dist.i386-apple-darwin9.4.0/lib/libgrass_nviz.dylib',
needed by
`/Users/cmbarton/grass_dev/grass7_src/dist.i386-apple-darwin9.4.0/bin/nviz_cmd'.
Stop.
No idea here.
2008/7/6 Michael Barton <michael.barton@asu.edu>:
that's Glynn's fix:-)
Errors in:
I have updated Makefile in lib/nviz based on lib/ogsf/Makefile, maybe
it can help, I can compile on my Linux box without problems.
http://trac.osgeo.org/grass/changeset/32032/grass/trunk/lib/nviz/Makefile
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa *
On Jul 6, 2008, at 3:23 PM, Markus Neteler wrote:
Errors in:
OR the GL include path is missing?
Yeah, I vaguely recall seeing a workaround for errors like this - something to do with Cursor being used in Carbon I think. Maybe the workaround is in TclTk?
I haven't attempted trunk yet. I'll give it a spin today and see if I think of anything.
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
Theory of the Universe
There is a theory which states that if ever anyone discovers exactly what the universe is for and why it is here, it will instantly disappear and be replaced by something even more bizarrely inexplicable. There is another theory which states that this has already happened.
-Hitchhiker's Guide to the Galaxy 2nd season intro
Errors in:
Just noticing that nviz gets its own library now, probably so that there can be a tcltk nviz and wxpython nviz without duplicating the core nviz features. Now here's something that gets tricky with OSX.
TclTk in OSX has never really worked all that well for NVIZ in the "Aqua" OpenGL configuration. Only the X11 configuration has worked reliably for NVIZ. So most people will be configuring for X11.
So, assuming that you configure for X11 OpenGL/TclTk, the NVIZ library will be made for X11 OpenGL. But wxPython OpenGL will be "Aqua" no matter what. I don't know if this is the source of the current errors, but it will certainly be a problem later.
Either the GUI will have to be an either/or choice (or just ignore TclTk GUI), or we need to make sure NVIZ TclTk works in the OSX Aqua configuration so they can be configured together.
For the immediate problems, I'd say configure with Aqua and disable TclTk NVIZ compilation.
--with-opengl=aqua --without-tcltk --without-x
First Pogril: Why is life like sticking your head in a bucket filled with hyena offal?
Second Pogril: I don't know. Why IS life like sticking your head in a bucket filled with hyena offal?
First Pogril: I don't know either. Wretched, isn't it?
-HitchHiker's Guide to the Galaxy
2008/7/6 William Kyngesburye <woklist@kyngchaos.com>:
experimental nvizlib is used by new nviz_cmd (visualization/nviz2/cmd)
module and wxGUI Nviz extension (gui/wxpython/nviz), no relation to
TCL/TK Nviz.
Martin
I'm sure that OpenGL is on my machine somewhere, but can't find it at the moment. Once I do, I can check for gl.h and report it's path back to you all.
Michael
____________________
Phone: 480-965-6262
Fax: 480-965-7671
Errors in:
I found it and this may be the issue. This refers back to an issue that William raised with Martin over compiling for Mac. The OpenGL that GRASS uses is located in /usr/X11/include/GL/gl.h.
That is, it uses the X11 version of GL for NVIZ. If the new lib is building for wxPython, then it needs an Aqua version of GL. I think that this exists, but still don't know where it is.
Once we find it, however, we somehow need to have GRASS compile the old NVIZ (i.e., in TclTk) with the X11 GL and the new wxPython NVIZ to use the native Aqua version. This may make compiling on Mac somewhat more complicated.
Michael
Phone: 480-965-6262
Fax: 480-965-7671
Errors in:
Here is the location of the native OGL (called AGL on Mac).
/System/Library/Frameworks/AGL.framework/Versions/A/Headers/gl.h
Michael
Phone: 480-965-6262
Fax: 480-965-7671
Errors in:
Which is a symlink to /System/Library/Frameworks/OpenGL.frameworks/Headers/gl.h. Which is what you get when you configure with --with-opengl=aqua.
Which spits out a bunch cpp errors in the Carbon includes, from the AGL include. More than I can wrap my brain around at the moment, but it looks like we need to work on this.
more complicated.
Both depend upon lib/ogsf, which (I suspect) can only be compiled for
one particular version of OpenGL.
If you want to continue using NVIZ on the Mac, I strongly suggest that
you figure out how to get NVIZ working with the native OpenGL and
Tcl/Tk.
Note that lib/nviz/render.c contains unconditional references to glX
functions, so it won't compile with non-X11 versions of OpenGL.
To make it work on all platforms, each section of code which uses glX
functions will need equivalent agl and wgl versions. The commment at
the top of that file indicates that it was based upon Togl, which
should have all of the relevant code.
Also, the Mac version of OpenGL needs <OpenGL/gl.h> rather than
<GL/gl.h>, e.g.:
#include <grass/config.h>
#if defined(OPENGL_X11) || defined(OPENGL_WINDOWS)
#include <GL/gl.h>
#endif
#ifdef OPENGL_AQUA
#include <OpenGL/gl.h>
#endif
Thanks for these important points Glynn.
Michael
______________________________
School of Human Diversity & Social Change
Tempe, AZ 85287-2402
USA
voice: 480-965-6262; fax: 480-965-7671
<GL/gl.h>, e.g.:
#include <GL/gl.h>
#endif
#ifdef OPENGL_AQUA
#endif
2008/7/7 Glynn Clements <glynn@gclements.plus.com>:
<GL/gl.h>, e.g.:
#include <GL/gl.h>
#endif
#ifdef OPENGL_AQUA
#endif
thanks for notes, I have updated render.c [1], nothing for wgl since
include/Make/Platform.make doesn't seems to have OPENGL_WGL (todo).
I am not sure about Xlib-based functions (XFreePixmap, XOpenDisplay,
XCreatePixmap)...
Martin
[1] http://trac.osgeo.org/grass/changeset/32043
2008/7/8 Martin Landa <landa.martin@gmail.com>:
sorry, there is OPENGL_WINDOWS, my mistake.
Martin
XCreatePixmap)...
For a GUI application, you wouldn't normally be calling these; you
would let the toolkit handle it. In particular, you would need to use
the same Display* used by the GUI; getting a new Display* from
XOpenDisplay() may not work, even if it refers to the same display.
2008/7/9 Glynn Clements <glynn@gclements.plus.com>:
XCreatePixmap)...
right, it is just used by CLI module (visualization/nviz2/cmd) for
off-screen rendering.
Martin
Learned a new trick today (probably standard stuff for the programming gurus) - I added -E to the compile flags and found that an unexpected macro was substituted for a buried Carbon struct:
typedef struct CMFixedXYZColor {
   Fixed X;
   Fixed Y;
   Fixed Z;
} CMFixedXYZColor;
which came out as:
   Fixed 0;
   Fixed 1;
   Fixed 2;
} CMFixedXYZColor;
It appears X, Y and Z (all caps, that is) are defined in gstypes.h in GRASS. I was able to fix the problem by moving the lines in nviz.h:
#include <grass/gsurf.h>
#include <grass/gstypes.h>
to *after* the GL includes.
Earth: "Mostly harmless"
- revised entry in the HitchHiker's Guide to the Galaxy
Which I would have found if I had updated my SVN today... Sorry, I wasn't paying attention, and it moved too fast :wink:
[Trillian] What are you supposed to do WITH a maniacally depressed robot?
[Marvin] You think you have problems? What are you supposed to do if you ARE a maniacally depressed robot? No, don't try and answer, I'm 50,000 times more intelligent than you and even I don't know the answer...
- HitchHiker's Guide to the Galaxy
But, there is this in gui/wxpython/nviz/nviz.h:
#include <grass/gis.h>
#include <grass/nviz.h>
Since <grass/nviz.h> already includes gsurf.h and gstypes.h, perhaps those should be removed to let <grass/nviz.h> handle the proper include order?
"Oh, look, I seem to have fallen down a deep, dark hole. Now what does that remind me of? Ah, yes - life."
- Marvin
