There are some errors when I compiled Grass 6.4 in Unbuntu 11.10.
Errors in:
/usr/local/src/grass64_release/lib/ogsf
/usr/local/src/grass64_release/lib/nviz
/usr/local/src/grass64_release/misc/m.nviz.image
/usr/local/src/grass64_release/visualization/nviz
In case of errors please change into the directory with error and run ‘make’.
If you get multiple errors, you need to deal with them in the order they
appear in the error log. If you get an error building a library, you will
also get errors from anything which uses the library.
I went to /usr/local/src/grass64_release/lib/ogsf and run ‘make’.
gcc -I/usr/local/src/grass64_release/dist./include -g -fPIC -DPACKAGE="“grasslibs”" -I/usr/include/gdal -DPACKAGE="“grasslibs”" -I/usr/include/libavcodec -I/usr/include/libavformat -I/usr/include/libswscale -I/usr/local/src/grass64_release/dist./include -o OBJ./gsd_img_mpeg.o -c gsd_img_mpeg.c
gsd_img_mpeg.c: In function ‘add_video_stream’:
gsd_img_mpeg.c:69:21: error: ‘CODEC_TYPE_VIDEO’ undeclared (first use in this function)
gsd_img_mpeg.c:69:21: note: each undeclared identifier is reported only once for each function it appears in
gsd_img_mpeg.c: In function ‘open_video’:
gsd_img_mpeg.c:161:5: warning: ‘avcodec_open’ is deprecated (declared at /usr/include/libavcodec/avcodec.h:3650) [-Wdeprecated-declarations]
gsd_img_mpeg.c: In function ‘write_video_frame’:
gsd_img_mpeg.c:218:15: error: ‘PKT_FLAG_KEY’ undeclared (first use in this function)
gsd_img_mpeg.c: In function ‘gsd_init_mpeg’:
gsd_img_mpeg.c:304:9: warning: assignment makes pointer from integer without a cast [enabled by default]
gsd_img_mpeg.c:307:6: warning: assignment makes pointer from integer without a cast [enabled by default]
gsd_img_mpeg.c:315:8: warning: assignment makes pointer from integer without a cast [enabled by default]
gsd_img_mpeg.c:336:5: warning: ‘av_set_parameters’ is deprecated (declared at /usr/include/libavformat/avformat.h:1363) [-Wdeprecated-declarations]
gsd_img_mpeg.c:341:5: warning: ‘dump_format’ is deprecated (declared at /usr/include/libavformat/avformat.h:1485) [-Wdeprecated-declarations]
gsd_img_mpeg.c:350:2: warning: ‘url_fopen’ is deprecated (declared at /usr/include/libavformat/avio.h:278) [-Wdeprecated-declarations]
gsd_img_mpeg.c:357:5: warning: ‘av_write_header’ is deprecated (declared at /usr/include/libavformat/avformat.h:1421) [-Wdeprecated-declarations]
gsd_img_mpeg.c: In function ‘gsd_close_mpeg’:
gsd_img_mpeg.c:442:2: warning: ‘url_fclose’ is deprecated (declared at /usr/include/libavformat/avio.h:279) [-Wdeprecated-declarations]
make: *** [OBJ./gsd_img_mpeg.o] Error 1
I went to /usr/local/src/grass64_release/lib/nviz and run ‘make’.
gcc -shared -o /usr/local/src/grass64_release/dist./lib/libgrass_nviz.6.4.3svn.so -L/usr/local/src/grass64_release/dist./lib -Wl,–export-dynamic -L/usr/lib64 -Wl,-rpath-link,/usr/local/src/grass64_release/dist./lib OBJ./change_view.o OBJ./cplanes_obj.o OBJ./draw.o OBJ./exag.o OBJ./lights.o OBJ./map_obj.o OBJ./nviz.o OBJ./position.o OBJ./render.o -lgrass_gis.6.4.3svn -lgrass_datetime.6.4.3svn -lz -lgrass_bitmap.6.4.3svn -lgrass_linkm.6.4.3svn -lgrass_vect.6.4.3svn -lgrass_dbmibase.6.4.3svn -lgrass_gis.6.4.3svn -lgrass_datetime.6.4.3svn -lz -lgrass_dbmiclient.6.4.3svn -lgrass_dbmibase.6.4.3svn -lgrass_gis.6.4.3svn -lgrass_datetime.6.4.3svn -lz -lgrass_gis.6.4.3svn -lgrass_datetime.6.4.3svn -lz -lgrass_dgl.6.4.3svn -lgrass_dig2.6.4.3svn -lgrass_gis.6.4.3svn -lgrass_datetime.6.4.3svn -lz -lgrass_rtree.6.4.3svn -lgrass_gis.6.4.3svn -lgrass_datetime.6.4.3svn -lz -lgrass_linkm.6.4.3svn -lgrass_rtree.6.4.3svn -lgrass_dig2.6.4.3svn -lgrass_gis.6.4.3svn -lgrass_datetime.6.4.3svn -lz -lgrass_rtree.6.4.3svn -lgrass_dgl.6.4.3svn -lgrass_rtree.6.4.3svn -lgrass_linkm.6.4.3svn -lgrass_dbmiclient.6.4.3svn -lgrass_dbmibase.6.4.3svn -lgrass_gis.6.4.3svn -lgrass_datetime.6.4.3svn -lz -lgrass_gis.6.4.3svn -lgrass_datetime.6.4.3svn -lz -lgrass_dbmibase.6.4.3svn -lgrass_gis.6.4.3svn -lgrass_datetime.6.4.3svn -lz -L/usr/lib -lgdal1.7.0 -lgeos_c -ltiff -lavutil -lavcodec -lavformat -lgrass_sites.6.4.3svn -lgrass_datetime.6.4.3svn -lgrass_dbmibase.6.4.3svn -lgrass_gis.6.4.3svn -lgrass_datetime.6.4.3svn -lz -lgrass_dbmiclient.6.4.3svn -lgrass_dbmibase.6.4.3svn -lgrass_gis.6.4.3svn -lgrass_datetime.6.4.3svn -lz -lgrass_gis.6.4.3svn -lgrass_datetime.6.4.3svn -lz -lgrass_gis.6.4.3svn -lgrass_datetime.6.4.3svn -lz -lgrass_vect.6.4.3svn -lgrass_dbmibase.6.4.3svn -lgrass_gis.6.4.3svn -lgrass_datetime.6.4.3svn -lz -lgrass_dbmiclient.6.4.3svn -lgrass_dbmibase.6.4.3svn -lgrass_gis.6.4.3svn -lgrass_datetime.6.4.3svn -lz -lgrass_gis.6.4.3svn -lgrass_datetime.6.4.3svn -lz -lgrass_dgl.6.4.3svn -lgrass_dig2.6.4.3svn -lgrass_gis.6.4.3svn -lgrass_datetime.6.4.3svn -lz -lgrass_rtree.6.4.3svn -lgrass_gis.6.4.3svn -lgrass_datetime.6.4.3svn -lz -lgrass_linkm.6.4.3svn -lgrass_rtree.6.4.3svn -lgrass_g3d.6.4.3svn -lgrass_gis.6.4.3svn -lgrass_datetime.6.4.3svn -lz -lgrass_ogsf.6.4.3svn -lgrass_bitmap.6.4.3svn -lgrass_linkm.6.4.3svn -lgrass_g3d.6.4.3svn -lgrass_gis.6.4.3svn -lgrass_datetime.6.4.3svn -lz -lgrass_gis.6.4.3svn -lgrass_datetime.6.4.3svn -lz -lgrass_sites.6.4.3svn -lgrass_datetime.6.4.3svn -lgrass_dbmibase.6.4.3svn -lgrass_gis.6.4.3svn -lgrass_datetime.6.4.3svn -lz -lgrass_dbmiclient.6.4.3svn -lgrass_dbmibase.6.4.3svn -lgrass_gis.6.4.3svn -lgrass_datetime.6.4.3svn -lz -lgrass_gis.6.4.3svn -lgrass_datetime.6.4.3svn -lz -lgrass_gis.6.4.3svn -lgrass_datetime.6.4.3svn -lz -lgrass_vect.6.4.3svn -lgrass_dbmibase.6.4.3svn -lgrass_gis.6.4.3svn -lgrass_datetime.6.4.3svn -lz -lgrass_dbmiclient.6.4.3svn -lgrass_dbmibase.6.4.3svn -lgrass_gis.6.4.3svn -lgrass_datetime.6.4.3svn -lz -lgrass_gis.6.4.3svn -lgrass_datetime.6.4.3svn -lz -lgrass_dgl.6.4.3svn -lgrass_dig2.6.4.3svn -lgrass_gis.6.4.3svn -lgrass_datetime.6.4.3svn -lz -lgrass_rtree.6.4.3svn -lgrass_gis.6.4.3svn -lgrass_datetime.6.4.3svn -lz -lgrass_linkm.6.4.3svn -lgrass_rtree.6.4.3svn -lgrass_vect.6.4.3svn -lgrass_dbmibase.6.4.3svn -lgrass_gis.6.4.3svn -lgrass_datetime.6.4.3svn -lz -lgrass_dbmiclient.6.4.3svn -lgrass_dbmibase.6.4.3svn -lgrass_gis.6.4.3svn -lgrass_datetime.6.4.3svn -lz -lgrass_gis.6.4.3svn -lgrass_datetime.6.4.3svn -lz -lgrass_dgl.6.4.3svn -lgrass_dig2.6.4.3svn -lgrass_gis.6.4.3svn -lgrass_datetime.6.4.3svn -lz -lgrass_rtree.6.4.3svn -lgrass_gis.6.4.3svn -lgrass_datetime.6.4.3svn -lz -lgrass_linkm.6.4.3svn -lgrass_rtree.6.4.3svn -lm -lSM -lICE -lX11 -L/usr/include/GL -lGL -L/usr/include/GL -lGLU
/usr/bin/ld: cannot find -lgrass_ogsf.6.4.3svn
collect2: ld returned 1 exit status
make: *** [/usr/local/src/grass64_release/dist./lib/libgrass_nviz.6.4.3svn.so] Error 1
I don’t know how to deal with these errors. Is there anyone can help me? Thank you so much.
