William Kyngesburye wrote:
Here's what I came up with. It uses an env var, GRASS_ADDON_ETC,
much like the PATH and GRASS_ADDON_PATH vars - a colon-delimited list
of paths to look in. And finally checks the GRASS application etc/.
It returns the full path to the found file or folder, or null if not
found.
The mechanism seems reasonable, although I have quite a few comments
on the implementation.
The main one is that I'd suggest using G_tokenize() to do most of the
work for you. Also, make the argument "const char *" (you don't need
to modify it) and use GPATH_MAX as the size of the path buffer (I've
been replacing various random constants with that value as I find
them; also for GNAME_MAX and GMAPSET_MAX)..
E.g. (untested):
static char *G__find_etc(const char *name)
const char *pathlist = getenv("GRASS_ADDON_ETC");
char path[GPATH_MAX];
if (pathlist)
char **dirs = G_tokenize(pathlist, ":");
char *result = NULL;
int i;
for (i = 0; dirs[i]; i++)
sprintf(path, "%s/%s", dirs[i], name);
if (access(path, 0) == 0)
result = G_store(path);
break;
G_free_tokens(dirs);
if (result)
return result;
sprintf(path, "%s/etc/%s", G_gisbase(), name);
return G_store(path);
return NULL;
Also:
#include <grass/etc.h>
Not needed; add it to gisdefs.h.
And a companion g.findetc for use in scripts:
exit(fpath==NULL);
exit(fpath ? EXIT_SUCCESS : EXIT_FAILURE);
