Hello Paul,
all the funny non-standard datum names, sigh (official EU data file!).
The original .prj content is:
PROJCS["ETRS_1989_LAEA",GEOGCS["GCS_ETRS_1989",DATUM["D_ETRS_1989",SPHEROID["GRS_1980",6378137.0,298.257222101]],PRIMEM["Greenwich",0.0],UNIT["Degree",0.0174532925199433]],PROJECTION["Lambert_Azimuthal_Equal_Area"],PARAMETER["False_Easting",4321000.0],PARAMETER["False_Northing",3210000.0],PARAMETER["Central_Meridian",10.0],PARAMETER["Latitude_Of_Origin",52.0],UNIT["Meter",1.0]]
Using your recent patch, it seems to work:
g.proj -w
PROJCS["Lambert Azimuthal Equal Area",
GEOGCS["grs80",
DATUM["European_Terrestrial_Reference_System_1989",
SPHEROID["Geodetic_Reference_System_1980",6378137,298.257222101]],
PRIMEM["Greenwich",0],
UNIT["degree",0.0174532925199433]],
PARAMETER["latitude_of_center",52],
PARAMETER["longitude_of_center",10],
PARAMETER["false_easting",4321000],
PARAMETER["false_northing",3210000],
UNIT["Meter",1]]
"grs80" was well detected.
Thanks for the quick fix, I have merged it into the 6.2-relbranch for 6.2.1.
On Tue, Nov 07, 2006 at 11:45:29AM +0000, Paul Kelly wrote:
Hello Markus
ETRS_1989 is a non-standard datum name (i.e. not what's in the EPSG
database) - it should be European_Terrestrial_Reference_System_1989. I've
committed a patch to CVS to handle the non-standard version so you should
try it now.
BTW (not relevant after the above patch, but interesting anyway) with my
updates from Sunday night I would think it should at least recognise the
ellipsoid, but it will probably put in WGS_1984 instead of GRS_1980 as
they are the same within the tolerances we can check - I'm not sure which
I should have first in the ellipsoid table (the first matching one will be
reported)!
Paul
On Tue, 7 Nov 2006, Markus Neteler wrote:
>Hi,
>I tried to create a new location from the CLC2000 data from
>EEA, distributed on DVD. The SHAPE file comes with a .proj file:
>ogrinfo -so 100kmE58N17.shp 100kmE58N17
>INFO: Open of `100kmE58N17.shp'
> using driver `ESRI Shapefile' successful.
>Layer name: 100kmE58N17
>Geometry: Polygon
>Feature Count: 392
>Extent: (5800000.000180, 1699999.999117) - (5867022.238090, 1799999.999127)
>Layer SRS WKT:
> DATUM["ETRS_1989",
> UNIT["Meter",1.0]]
>CODE_00: String (3.0)
>AREA_HA: Real (17.5)
>SHAPE_area: Real (19.11)
>SHAPE_len: Real (19.11)
>But GRASS creates the location like this:
>GRASS 6.3.cvs (clc2000):/tmp > g.proj -w
> GEOGCS["unnamed",
> DATUM["unknown",
> SPHEROID["unnamed",6378137,298.257222101]],
> UNIT["Meter",1]]
>g.proj -p
>-PROJ_INFO-------------------------------------------------
>name : Lambert Azimuthal Equal Area
>proj : laea
>a : 6378137.0
>es : 0.006694380022900787
>lat_0 : 52
>lon_0 : 10
>x_0 : 4321000
>y_0 : 3210000
>no_defs : defined
>-PROJ_UNITS------------------------------------------------
>unit : Meter
>units : Meters
>meters : 1
>What's the trick to make GRASS recognize it completely?
>thanks,
>Markus
>_______________________________________________
>grass-dev mailing list
>grass-dev@grass.itc.it
>http://grass.itc.it/mailman/listinfo/grass-dev
Markus Neteler <neteler itc it> http://mpa.itc.it/markus/
ITC-irst - Centro per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18 - 38050 Povo (Trento), Italy
