[GRASS-dev] Example python script
Does anybody has an example grass python script that deals with multiple layer input? For example with the input option below with #% multiple set to yes, I would like to create multiple variables, one for each map.
#%option
#% key: input
#% type: string
#% gisprompt: old,cell,raster
#% required: yes
#% multiple: yes
#%end
I am completely new to python, and besides python scripting tutorials and text books, for me using examples is a great way to accelerate the learning process. I have looked into the addon repository and scripts in the GRASS 7 SVN, but haven’t found what I was looking for.
More in general, does anybody have (simple) shell scripts that have now been converted in python scripts? I thought I had seen a page on the grass wiki where code snippets in shell and python were compared, but I can’t find it.
Paulo
each map.
#%option
#% key: input
#% type: string
#% required: yes
#% multiple: yes
#%end
the GRASS 7 SVN, but haven't found what I was looking for.
can't find it.
You can always look at the scripts in grass7. A quick grep through the directory shows:
i.spectral/i.spectral.py
r.buffer.lowmem/r.buffer.lowmem.py
r.in.wms/r.in.wms.py
v.db.addtable/v.db.addtable.py
v.db.univar/v.db.univar.py
v.in.wfs/v.in.wfs.py
v.krige/v.krige.py
Generally, you should be able to do something like this:
rastermaps = input.split(',')
and the access each maps like this:
my_map1 = rastermaps[0]
etc
Moritz
Thanks, I did take a look, but obviously not hard enough (btw, clever trick to use grep… will download the source code so I can use that too).
On Thu, Jan 31, 2013 at 5:12 PM, Moritz Lennert <mlennert@club.worldonline.be> wrote:
each map.
#%option
#% key: input
#% type: string
#% required: yes
#% multiple: yes
#%end
can’t find it.
v.krige/v.krige.py
rastermaps = input.split(‘,’)
etc
Moritz
