[GRASS-dev] Excel read support
since Excel files continue to be widely used, it would be a great help to
have direct read support in GRASS, e.g. for easy table joins.
I have found this library (which comes e.g. with Fedora as well as OSGeo4W):
https://github.com/python-excel/xlwt
(main page: http://www.python-excel.org/)
To always go through LibreOffice conversion or other tricks is a bit annoying...
Or am I missing an easy trick?
On Thu, 2012-08-16 at 19:38 +0200, Markus Neteler wrote:
grass-dev mailing list
grass-dev@lists.osgeo.org
Fedora also has Furieri's freexl, in case that helps.
Volker
Excellent (since we at FEM co-financed it :slight_smile: - I see it also on
http://download.osgeo.org/osgeo4w/versions.html
So two choices if Mac OSX and the Debian-style world also
have either/or or both...
On 16/08/12 20:33, Markus Neteler wrote:
Debian has xlrd (xlwt is for writing Excel files) in stable and freexl in testing.
However, why should we implement this in GRASS when OGR already supports Excel file reading (via freexl) ? Can't you just use db.in.ogr ?
Moritz
On Fri, Aug 17, 2012 at 11:48 AM, Moritz Lennert
Good point, I wasn't aware of that:
http://www.gdal.org/ogr/drv_xls.html
(GDAL/OGR >= 1.9.0)
So it won't be needed once the distros provide OGR with FreeXL support.
