[GRASS-dev] EXE_SUFFIX
Hi.
Can you tell me why EXE_SUFFIX was removed from Platform.make while
it was left in Module.make and other places?
http://freegis.org/cgi-bin/viewcvs.cgi/grass6/include/Make/Platform.make.in.diff?r1=1.54&r2=1.55
Consequently executables on windows don't have .exe extension.
Can you please enable .exe extensions again?
Radim
I changed the variable to $(EXE), as that tends to be more common (and
easier to read); EXE is set from EXEEXT, which is set by the AC_EXEEXT
autoconf macro.
I'll update Module.make accordingly.
autoconf macro.
EXE_SUFFIX is also used in other Makefile files where default
Module.make cannot be used, 53 files in total.
Radim
> autoconf macro.
I only found 12 files, although the number of occurrences of
EXE_SUFFIX may have been 53.
In any case, I've changed those also.
FWIW, I changed it due to errors the last time I built on MinGW, where
(for whatever reason), EXE_SUFFIX wasn't being set.
