[GRASS-dev] Export from GRASS to Postgres
Hi All,
I am trying to export GRASS maps/mapsets to PostgreSQL.At the time of installation of GRASS ,I have configured it with Postgres.
The command used is:
v.out.ogr -c input=fields type=area ‘dsn=PG:host=localhost dbname=grass user=grassuser password=grassuser’ olayer=fields2postgis layer=1 format=PostgreSQL
The database grass is postgis enabled.
However the format “PostgreSQL” is taken as invalid format.
Without “PostgreSql” format the maps are exported to ESRI_shapefile format.
One thing more, There is no PostgreSql format type in OGR format dropdown list in case of using GUI.
Please help me out.
Thanks in advance.
“If you don’t know where you are going any road will get you there”
Regards
Suprakash
2013/4/3 suprakash maitra <suprakashmaitra@yahoo.com>:
v.out.ogr -c input=fields type=area 'dsn=PG:host=localhost dbname=grass
user=grassuser password=grassuser' olayer=fields2postgis layer=1
format=PostgreSQL
`v.out.ogr` is using OGR library. In other words, GRASS must be
compiled with OGR support and your OGR installation must be compiled
with PostgreSQL support. Check available formats with
$ ogrinfo --formats | grep PostgreSQL
  -> "PostgreSQL" (read/write)
then v.out.ogr comes also with `format=PostgreSQL`.
In GRASS 7 you could try also a new module `v.out.postgis` which
allows to export GRASS vector maps to PostGIS without OGR library
(GRASS must be compiled with PostgreSQL support). This module also
allows to export vector data to PostGIS Topology [1] (under
development).
Martin
[1] http://grasswiki.osgeo.org/wiki/PostGIS_Topology
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
[again - please keep communication on ML!]
2013/4/4 suprakash maitra <suprakashmaitra@yahoo.com>:
v.out.ogr -c input=fields type=area dsn='PG:host=localhost dbname=grass
format=PostgreSQL
ERROR: value <PostgreSQL> out of range for parameter
<format>
as I mentioned earlier, your GDAL/OGR must be compiled with PostgreSQl
support [1].
Martin
[1] http://gdal.org/ogr/drv_pg.html
[please don't send me private mails, keep the communication on ML,
please don't ignore it!]
2013/4/5 suprakash maitra <suprakashmaitra@yahoo.com>:
[root@lab35 grass-6.4.2]#./configure
--with-postgres-includes=/opt/PostgreSQL/9.1/include
--with-postgres-libs=/opt/PostgreSQL/9.1/lib
--with-freetype-includes=/usr/include/freetype2
--with-freetype-libs=/usr/lib --with-cxx --with-python --with-fftw
--with-freetype --with-gdal=/usr/local/bin/gdal-config --with-postgres
GRASS is installed and configured with postgres
As I noted *earlier*, v.out.ogr is using OGR library to export data to
PostgreSQL/PostGIS. So it's not related to this problem.
then
[root@lab35 gdal-1.8.1]#./configure
--with-grass=/usr/local/grass-6.4.2/dist.i686-pc-linux-gnu
--with-libgrass=/usr/local/grass-6.4.2/dist.i686-pc-linux-gnu/lib
--with-pg=/opt/PostgreSQL/9.1/bin/pg_config
gdal is configured with grass and postgres
You don't need to compile GDAL with GRASS support, unless you want use
OGR GRASS driver [1]. None of r.[in|out].gdal and v.[in|out].ogr
modules do not use this driver.
after that I have got the output with the command:
Even then the format "PostgreSQL" is not supported.
Are you sure that you compile GRASS against the same GDAL/OGR version.
It could be that you have more GDAL/OGR installations on your machine.
Martin
[1] http://gdal.org/ogr/drv_grass.html
Hi
I am using Fedora15,GRASS-6.4.2,gdal-1.8.1,postgresql-9.1.I have compiled gdal with postgresql support and GRASS with gdal and postgreSQL support ,even then while exporting map/mapset to postgreSQL the format PostgreSQL is not supported.
Plz help me out.
Regards
Suprakash
To:grass-dev@lists.osgeo.orggrass-dev@lists.osgeo.org
Sent: Wednesday, April 3, 2013 5:44 PM
Subject: Export from GRASS to Postgres
Hi All,
Please help me out.
Thanks in advance.
Regards
Suprakash
On 08/04/13 12:30, suprakash maitra wrote:
Hi
Plz help me out.
Can you check the outputs of:
v.in.ogr -f
and
ogrinfo --formats
v.in.ogr -f
ESRI Shapefile (rw): ESRI Shapefile
MapInfo File (rw): MapInfo File
UK .NTF (ro): UK .NTF
SDTS (ro): SDTS
TIGER (rw): TIGER
S57 (rw): S57
DGN (rw): DGN
VRT (ro): VRT
REC (ro): REC
Memory (rw): Memory
BNA (rw): BNA
CSV (rw): CSV
GML (rw): GML
GPX (rw): GPX
KML (rw): KML
GeoJSON (rw): GeoJSON
GMT (rw): GMT
SQLite (rw): SQLite
PCIDSK (rw): PCIDSK
XPlane (ro): XPlane
AVCBin (ro): AVCBin
AVCE00 (ro): AVCE00
DXF (rw): DXF
Geoconcept (rw): Geoconcept
GeoRSS (rw): GeoRSS
GPSTrackMaker (rw): GPSTrackMaker
VFK (ro): VFK
PGDump (rw): PGDump
GPSBabel (rw): GPSBabel
SUA (ro): SUA
OpenAir (ro): OpenAir
PDS (ro): PDS
WFS (ro): WFS
HTF (ro): HTF
AeronavFAA (ro): AeronavFAA
Available OGR Drivers:
(Mon Apr 8 18:17:56 2013) Command finished (0 sec)
[user@lab35 local]$ ogrinfo --formats
Supported Formats:
→ “ESRI Shapefile” (read/write)
→ “MapInfo File” (read/write)
→ “UK .NTF” (readonly)
→ “SDTS” (readonly)
→ “TIGER” (read/write)
→ “S57” (read/write)
→ “DGN” (read/write)
→ “VRT” (readonly)
→ “REC” (readonly)
→ “Memory” (read/write)
→ “BNA” (read/write)
→ “CSV” (read/write)
→ “GML” (read/write)
→ “GPX” (read/write)
→ “KML” (read/write)
→ “GeoJSON” (read/write)
→ “GMT” (read/write)
→ “SQLite” (read/write)
→ “PostgreSQL” (read/write)
→ “PCIDSK” (read/write)
→ “XPlane” (readonly)
→ “AVCBin” (readonly)
→ “AVCE00” (readonly)
→ “DXF” (read/write)
→ “Geoconcept” (read/write)
→ “GeoRSS” (read/write)
→ “GPSTrackMaker” (read/write)
→ “VFK” (readonly)
→ “PGDump” (read/write)
→ “GPSBabel” (read/write)
→ “SUA” (readonly)
→ “OpenAir” (readonly)
→ “PDS” (readonly)
→ “WFS” (readonly)
→ “HTF” (readonly)
→ “AeronavFAA” (readonly)
Regards
Suprakash
Sent: Monday, April 8, 2013 4:00 PM
Subject: Re: Export from GRASS to Postgres
Hi
Plz help me out.
Regards
Suprakash
Hi All,
Please help me out.
Thanks in advance.
Regards
Suprakash
2013/4/8 suprakash maitra <suprakashmaitra@yahoo.com>:
then GRASS is probably using different GDAL library which is built
without PostgreSQL. Check if there are more GDAL installations on your
machine. See the previous answer.
Martin
2013/4/8 Martin Landa <landa.martin@gmail.com>:
in other words, what says?
ogrinfo --version
gdal-config --libs
g.version -e (in GRASS 7)
or
g.version -b (in GRASS 6)
Martin
Hi
You have given some commands,on the basis of that o/p is as follows:
[user@lab35 ~]$ ogrinfo --version
GDAL 1.8.1, released 2011/07/09
[user@lab35 ~]$ gdal-config --libs
-L/usr/local/lib -lgdal
[user@lab35 ~]$
./configure --with-postgres-includes=/opt/PostgreSQL/9.1/include --with-postgres-libs=/opt/PostgreSQL/9.1/lib --with-freetype-includes=/usr/include/freetype2 --with-freetype-libs=/usr/lib --with-cxx --with-python --with-fftw --with-freetype --with-gdal=/usr/local/bin/gdal-config --with-postgres
according to you there is a different GDAL library,
then how can check it or what should I do with it,to get things done.
Thanks in advance
Regards
suprakash
Sent: Monday, April 8, 2013 6:21 PM
v.in.ogr -f
SDTS (ro): SDTS
TIGER (rw): TIGER
S57 (rw): S57
DGN (rw): DGN
VRT (ro): VRT
REC (ro): REC
Memory (rw): Memory
BNA (rw): BNA
CSV (rw): CSV
GML (rw): GML
GPX (rw): GPX
KML (rw): KML
GMT (rw): GMT
SQLite (rw): SQLite
PCIDSK (rw): PCIDSK
XPlane (ro): XPlane
AVCBin (ro): AVCBin
AVCE00 (ro): AVCE00
DXF (rw): DXF
GeoRSS (rw): GeoRSS
VFK (ro): VFK
PGDump (rw): PGDump
SUA (ro): SUA
PDS (ro): PDS
WFS (ro): WFS
HTF (ro): HTF
Supported Formats:
→ “SDTS” (readonly)
→ “VRT” (readonly)
→ “REC” (readonly)
→ “VFK” (readonly)
→ “SUA” (readonly)
→ “PDS” (readonly)
→ “WFS” (readonly)
→ “HTF” (readonly)
Regards
Suprakash
Hi
Plz help me out.
Regards
Suprakash
Hi All,
Please help me out.
Thanks in advance.
Regards
Suprakash
2013/4/9 suprakash maitra <suprakashmaitra@yahoo.com>:
and what says?
$ which gdal-config
is PostgreSQL included in
/usr/local/bin/ogrinfo --formats
Seems like that you have two GDAL installations (in /usr and /usr/local).
Martin
$ which gdal-config
and version is:CONFIG_VERSION=“1.8.1”
[user@lab35 local]$ /usr/local/bin/ogrinfo --formats
Supported Formats:
→ “SDTS” (readonly)
→ “VRT” (readonly)
→ “REC” (readonly)
then what to do?
Regards
suprakash
Sent: Tuesday, April 9, 2013 1:32 PM
Hi
[user@lab35 ~]$
Thanks in advance
Regards
suprakash
v.in.ogr -f
SDTS (ro): SDTS
TIGER (rw): TIGER
S57 (rw): S57
DGN (rw): DGN
VRT (ro): VRT
REC (ro): REC
Memory (rw): Memory
BNA (rw): BNA
CSV (rw): CSV
GML (rw): GML
GPX (rw): GPX
KML (rw): KML
GMT (rw): GMT
SQLite (rw): SQLite
PCIDSK (rw): PCIDSK
XPlane (ro): XPlane
AVCBin (ro): AVCBin
AVCE00 (ro): AVCE00
DXF (rw): DXF
GeoRSS (rw): GeoRSS
VFK (ro): VFK
PGDump (rw): PGDump
SUA (ro): SUA
PDS (ro): PDS
WFS (ro): WFS
HTF (ro): HTF
Supported Formats:
→ “SDTS” (readonly)
→ “VRT” (readonly)
→ “REC” (readonly)
→ “VFK” (readonly)
→ “SUA” (readonly)
→ “PDS” (readonly)
→ “WFS” (readonly)
→ “HTF” (readonly)
Regards
Suprakash
Hi
Plz help me out.
Regards
Suprakash
Hi All,
Please help me out.
Thanks in advance.
Regards
Suprakash
