[GRASS-dev] export question
I am trying to export an image to an excel file having lat, long, rgb values
for all the points on the image. Does anyone know where I should look, have
some idea...any help would be greatly appreciated
View this message in context: http://osgeo-org.1803224.n2.nabble.com/export-question-tp6777072p6777072.html
Sent from the Grass - Dev mailing list archive at Nabble.com.
You could try r.out.xyz for each layer , then join the columns .
http://grass.fbk.eu/grass64/manuals/html64_user/r.out.xyz.html
Doug Newcomb
USFWS
Raleigh, NC
919-856-4520 ext. 14 doug_newcomb@fws.gov
The opinions I express are my own and are not representative of the official policy of the U.S.Fish and Wildlife Service or Dept. of the Interior. Life is too short for undocumented, proprietary data formats.
sarthakahuja <sarthakahuja@gmail.com>
Sent by: grass-dev-bounces@lists.osgeo.org
09/09/2011 03:37 PM
To
grass-dev@lists.osgeo.org
cc
Subject
View this message in context: ``http://osgeo-org.1803224.n2.nabble.com/export-question-tp6777072p6777072.html
grass-dev mailing list
thanks a lot, do you know how to get their red, green, blue values (0-255)
View this message in context: http://osgeo-org.1803224.n2.nabble.com/export-question-tp6777072p6777617.html
for the basic palette, try the r.colors.out in newer versions of
GRASS.
or create 3 new maps with r.mapcalc's # operator, then r.out.xyz
for those:
r.mapcalc map.red = r#map
r.mapcalc map.green = g#map
r.mapcalc map.blue = b#map
Hamish
by the way, you'll want to use a very small region or very new
64bit version of Excel or else it won't accept the many rows
which a dump of a raster image creates.
big matrix datasets is why Matlab/Octave/Scilab (& raster GIS) was
invented :wink:
Hamish
This:
  r.mapcalc "map.red = r#map ; map.green = g#map ; map.blue = b#map"
is more efficient, as it only reads the input map once.
Is this possible using grass jni. I looked into its library but could not
find functions for these commands
http://sorokine.info/grass-jni/htmls/index.html
If not, is there another way I could do this using java
View this message in context: http://osgeo-org.1803224.n2.nabble.com/export-question-tp6777072p6824719.html
On Fri, Sep 23, 2011 at 5:49 PM, sarthakahuja <sarthakahuja@gmail.com> wrote:
See http://sorokine.info/grass-jni/ - it is there only for historical reasons.
Perhaps through jython in order to use the nice new Python bindings?
Of course also via the new vtk-grass-bridge with JAVA bindings.
See also
http://grass.osgeo.org/wiki/GRASS_and_Java
