[GRASS-dev] Extracting coordinates of RasterNumpy objects (pygrass)
I am using (with enthusiasm!) Pietro’s pygrass library to develop a raster module. I am using Numpy/Scipy as my working horse, so I manipulate a lot of the RasterNumpy objects that have been introduced with pygrass.
In a specific step, I am identifying pixels using a test (this would be similar to my_array < 100). I would like to extract the points that satisfy the test, and access not only their values and index in the array, but I would also go back to their coordinates to extract them as (x, y, z).
Is there a way to do this using RasterNumpy and pygrass?
Pierre
Hi Pierre,
On Mon, Dec 17, 2012 at 7:48 AM, Pierre Roudier
<pierre.roudier@gmail.com> wrote:
I am using (with enthusiasm!) Pietro's pygrass library to develop a raster
I'm really happy that you are using the pygrass library! :wink:
yes, you should use the numpy stuff, something like:
import numpy as np
a = np.arange(15).reshape(3, 5)
a
array([[ 0, 1, 2, 3, 4],
       [ 5, 6, 7, 8, 9],
       [10, 11, 12, 13, 14]])
b = a>7
b1
array([[False, False, False, False, False],
       [False, False, False, True, True],
       [ True, True, True, True, True]], dtype=bool)
b.nonzero() # return two array with x and y and z if the array is 3D
(array([1, 1, 2, 2, 2, 2, 2]), array([3, 4, 0, 1, 2, 3, 4]))
Please let me know if you find something that is not clear, or is not
working properly...
All the best!
Pietro
Thanks Pietro,
Yes that answers the question, but just partly: I was actually
wondering whether it would be possible to get the extracted x and y
coordinates in geographic space (as opposed to the Numpy array space)?
Thanks again for the great work on pygrass,
P
2012/12/17 Pietro <peter.zamb@gmail.com>:
Hi Pierre,
import numpy as np
a
       [ 5, 6, 7, 8, 9],
b = a>7
b1
working properly...
All the best!
Pietro
Scientist
Landcare Research, New Zealand
Hi Pierre,
in pygrass you can find the function pixel2coor((col, row), region)
that will transform your column and row into a (northing, easting)
tuple. It is defined in pygrass/functions.py . Internally
Rast_row_to_northing() and Rast_col_to_easting() from the GRASS raster
library are used.
Best regards
Soeren
2012/12/17 Pierre Roudier <pierre.roudier@gmail.com>:
Pierre
grass-dev mailing list
grass-dev@lists.osgeo.org
Hi Pierre,
On Mon, Dec 17, 2012 at 9:44 PM, Pierre Roudier
Thanks Pietro,
aah sorry, I forgot to say that you can use pixel2coord... see the
example below:
from grass import pygrass
from pygrass.raster import RasterNumpy
from pygrass.region import Region
from pygrass.functions import pixel2coor
elev = RasterNumpy("elevation")
elev.open()
a = elev > 144
reg = Region()
xcoords, ycoords = a.nonzero()
for pixel in zip(list(xcoords), list(ycoords))[:5]:
... print pixel
(0, 6)
(0, 7)
(0, 8)
(0, 9)
(0, 10)
... print pixel2coor(pixel, reg)
(228440.0, 630000.0)
(228430.0, 630000.0)
(228420.0, 630000.0)
(228410.0, 630000.0)
(228400.0, 630000.0)
Best regards
Pietro
Thanks Pietro and Soeren,
That's really great!
I am looking forward to use this with v.surf.bspline to do on the fly
interpolation (interpolation with SciPy is quite slow and memory
hungry). I am coding an iterative process that calls the interpolation
routine a lot of times (~10 to 40 interpolation steps), so I would
like to make the most of GRASS interpolation power.
Pierre
2012/12/18 Pietro <peter.zamb@gmail.com>:
Hi Pierre,
Thanks Pietro,
example below:
elev.open()
a = elev > 144
reg = Region()
... print pixel
(0, 6)
(0, 7)
(0, 8)
(0, 9)
(0, 10)
Best regards
Pietro
Scientist
Sorry Pietro - more questions as I'm working my way through this new tool!
- As a follow-up from my last question, I am trying to convert the
pixels I have identified in my raster to a vector layer. While I
manage to create a Point() from scratch, I can't find out how I could
append coordinates to add more points to it. Using the previous
example:
elev.open()
a = elev > 144
reg = Region()
# Switch to geographic space
coords = [pixel2coor(pixel, reg) for pixel in zip(list(xcoords), list(ycoords))]
# Add attribute column
xyz = np.column_stack((np.asarray(coords), z))
from pygrass.vector import *
p = pygrass.vector.geometry.Point() # Works
p = pygrass.vector.geometry.Point(x = xyz[:,0], y = xyz[:,1], z=xyz[:,2]) # Fails
- Is there a method to create a set of points (class Point) and write
it into the GRASS database?
- I would like to use this {x,y,z} set of points in v.surf.bspline. I
don't suppose I got another choice but write my numpy array into the
GRASS database first right?
Thanks again for your work,
Pierre
2012/12/18 Pierre Roudier <pierre.roudier@gmail.com>:
Pierre
Hi Pierre,
Thanks Pietro,
example below:
elev.open()
a = elev > 144
reg = Region()
... print pixel
(0, 6)
(0, 7)
(0, 8)
(0, 9)
(0, 10)
Best regards
Pietro
Scientist
Scientist
Hi Pierre,
On Tue, Dec 18, 2012 at 1:50 AM, Pierre Roudier
<pierre.roudier@gmail.com> wrote:>
yes, but at the moment supports only 2D features... and I don't
understand why... :slight_smile:
it was supposed to work with:
# python source code
import numpy as np
from grass.pygrass.raster import RasterNumpy
from grass.pygrass.vector import VectorTopo
from grass.pygrass.vector.geometry import Point
from grass.pygrass.region import Region
from grass.pygrass.functions import pixel2coor
elev.open()
a = elev > 144
reg = Region()
nonzero = a.nonzero()
coords = np.array([pixel2coor(pixel, reg) for pixel in
np.column_stack(nonzero)])
points = np.rec.fromarrays([coords.T[0], coords.T[1], elev[nonzero]])
new = VectorTopo('newvect')
new.open("w", overwrite=True)
for pnt in points:
    new.write(Point(*pnt))
new.close()
new.build()
# end source code
actually, even if the point is a 3D point, the write method of the
Vector class it is writing only a 2D point... I miss something but I
don't know where...
I hope to fix this as soon as possible...
I don't think is in the database... I think it's enough if you write
the points in the GRASS topology file... And of course I think you
must do it, if you want to use the v.surf.bspline module...
Pietro
