they don't seem to be in CVS so problem is just left over local files.
("? path/filename" at start of processing with "cvs update -q")
In 6.3-cvs I have removed the tcltk web browsers from NVIZ and (the
duplicate) in lib/init/. Both were previously made redundant by Markus.
This saves ~ 240kb in the source tree.
RC2 builds fine on Debian/Sarge (tcltk 8.3).
For me, the welcome text is now large, but not huge:
Welcome to GRASS GIS Version 6.2.0RC2
The world's leading open source GIS
Select an existing project location and mapset
or define a new location
known release to-dos:
[high priority]
- refine the press release
- make v.digit 8.3 compatible, note "gis.m may need 8.4" in REQUIREMENTS.html
[minor]
- r.le.* G_calloc() before G_gisinit()
[optional]
- apply v.buffer patch? (trade bad known bug for lightly tested band-aid)
- remove TclTk web browser from NVIZ & lin/init/ (merge from HEAD)
CVS ignores files and directories which match specific patterns; by
default, the list includes "*.orig". It won't attempt to check in or
update such files, and they won't be listed with a "?" if you update a
directory.
From the CVS Info file:
: Ignoring files via cvsignore
: There are certain file names that frequently occur inside your
: working copy, but that you don't want to put under CVS control.
: Examples are all the object files that you get while you compile your
: sources. Normally, when you run `cvs update', it prints a line for
: each file it encounters that it doesn't know about (*note update
: output::).
: CVS has a list of files (or sh(1) file name patterns) that it should
: ignore while running `update', `import' and `release'. This list is
: constructed in the following way.
: * The list is initialized to include certain file name patterns:
: names associated with CVS administration, or with other common
: source control systems; common names for patch files, object files,
: archive files, and editor backup files; and other names that are
: usually artifacts of assorted utilities. Currently, the default
: list of ignored file name patterns is:
: RCS SCCS CVS CVS.adm
: RCSLOG cvslog.*
: tags TAGS
: .make.state .nse_depinfo
: *~ #* .#* ,* _$* *$
: *.old *.bak *.BAK *.orig *.rej .del-*
: *.a *.olb *.o *.obj *.so *.exe
: *.Z *.elc *.ln
: core
: * The per-repository list in `$CVSROOT/CVSROOT/cvsignore' is
: appended to the list, if that file exists.
: * The per-user list in `.cvsignore' in your home directory is
: appended to the list, if it exists.
: * Any entries in the environment variable `$CVSIGNORE' is appended
: to the list.
: * Any `-I' options given to CVS is appended.
: * As CVS traverses through your directories, the contents of any
: `.cvsignore' will be appended to the list. The patterns found in
: `.cvsignore' are only valid for the directory that contains them,
: not for any sub-directories.
: In any of the 5 places listed above, a single exclamation mark (`!')
: clears the ignore list. This can be used if you want to store any file
: which normally is ignored by CVS.
: Specifying `-I !' to `cvs import' will import everything, which is
: generally what you want to do if you are importing files from a
: pristine distribution or any other source which is known to not contain
: any extraneous files. However, looking at the rules above you will see
: there is a fly in the ointment; if the distribution contains any
: `.cvsignore' files, then the patterns from those files will be
: processed even if `-I !' is specified. The only workaround is to
: remove the `.cvsignore' files in order to do the import. Because this
: is awkward, in the future `-I !' might be modified to override
: `.cvsignore' files in each directory.
: Note that the syntax of the ignore files consists of a series of
: lines, each of which contains a space separated list of filenames.
: This offers no clean way to specify filenames which contain spaces, but
: you can use a workaround like `foo?bar' to match a file named `foo bar'
: (it also matches `fooxbar' and the like). Also note that there is
: currently no way to specify comments.
I looked at substituting bwidgets LabelFrame for the tk 8.4 labelframe. It
is not a drop in and has a bug in that it won't display the border. But it
will display the text.
I sent this to Markus (and thought I copied you, but maybe just imagined
that) on Thursday or Friday to see if it made any difference. I can't tell
because I don't have TclTk 8.3.
I'll send it here again. It goes ca. line 223 to replace labelframe...
LabelFrame .bpf -bd 1 -relief groove -side top -anchor n \
-text [G_msg "mouse button actions (left, right, center)"]
Except for not drawing the border, it is otherwise harmless on my Mac with
x11. I don't know what it does for Mac Aqua or Windows.
Michael
Arizona State University
Date: Sun, 8 Oct 2006 17:46:46 +1300
To: grass5 <grass-dev@grass.itc.it>
Subject: [GRASS-dev] extraneous files in grass-6.2.0RC2.tar.gz & 6.2.0 release
plans
[high priority]
[minor]
[optional]
