The following files are extraneous files that could probably be deleted.
Most of them are library tests. If they are to be kept, then may I
suggest we integrate them into 'make check' or the like:
- lib/bitmap/main.c
- lib/bitmap/smain.c
- lib/cdhc/cdh-f77.out
- lib/cdhc/test.c
- lib/cdhc/test.f
- lib/cdhc/shapiro1.c.save?
- lib/form/form.c?
- lib/linkm/try.c
- lib/linkm/try2.c
- lib/linkm/malloc.c
- lib/linkm/linkm.c
- lib/linkm/speed.c
- lib/linkm/speed2.c
- lib/linkm/speed3.c
- lib/segment/try.c
- lib/vector/diglib/test.c
- lib/vector/diglib/port_test.c
- lib/rtree/test.c
- lib/rtree/gammavol.c?
- lib/rtree/sphvol.c?
- lib/vector/test.c
Brad Douglas <rez touchofmadness com> KB8UYR
Address: 37.493,-121.924 / WGS84 National Map Corps #TNMC-3785
