t.rast.accumulate: created file differ from the reference
Needs investigation.
./temporal/t.rast.accumulate/testsuite/test.t.rast.accumulate.sh
t.rast.to.rast3: r3.univar ended successfully but we were expecting output and got nothing
The obvious issue here is that r3.univar (as well as r.univar) gives no output when only NULLs are present. This is strange and undocumented behavior. If the NULLs on the input are OK in this context, I don’t know.
./temporal/t.rast.to.rast3/testsuite/test_strds_to_rast3.py
pygrass/modules: Execution of subprocesses was not successful
Some problem with grid module which works otherwise, possibly just a problem with test. However, worth further investigation, grid module is fragile by nature, so tests should be thorough.
./lib/python/pygrass/modules/testsuite/test_doctests.py
pygrass: ‘VectorTopo’ object has no attribute ‘table’
My guess here is just a problem in a test itself.
./lib/python/pygrass/testsuite/test_doctests.py
gunitest: Only numeric column type is supported
Seems like the NC basic dataset has different column types then full NC. Needs further investigation. BTW, what about Datasets category for Trac?
./lib/python/gunittest/testsuite/test_assertions_vect.py
Overall report:
Executed 128 test files in 0:27:25.642203. >From them 120 files (94%) were successful and 8 files (6%) failed.
Individual tests: Status: 94%, Tests: 1368, Successful: 1358, Failed: 9, Percent successful: 99%
