I’m trying to begin to get caught with all the changes over the past couple weeks.
I updated from the SVN a couple hours ago, did a make distclean, installed new versions of William Kyngesburye’s frameworks and tried to compile.
There was an initial problem with one of the frameworks (see below) that William fixed in very short order (Thanks!!). Following the fix, configure ran fine with no errors.
But when I tried to compile, I hit 2 new errors and an old one that I list below. The old one is vdigit with wxPython. I know that we’re still wrestling with this, but wanted to report the current state on the Mac while I was covering other compile errors too. The new errors are in lib/external/shapelib and db/drivers/dbf
Errors in:
/Users/cmbarton/grass_dev/grass_src/lib/external/shapelib
/Users/cmbarton/grass_dev/grass_src/db/drivers/dbf
/Users/cmbarton/grass_dev/grass_src/gui/wxpython/vdigit
cmb-MBP-2:~/grass_dev/grass_src/lib/external cmbarton$ cd shapelib
cmb-MBP-2:~/grass_dev/grass_src/lib/external/shapelib cmbarton$ make
make lib
cc -dynamiclib -compatibility_version 6.3 -current_version 6.3 -install_name /Applications/Grass/GRASS-6.3.app/Contents/MacOS/lib/libgrass_shape.dylib -o /Users/cmbarton/grass_dev/grass_src/dist.i686-apple-darwin8.11.1/lib/libgrass_shape.6.3.svn.dylib -L/Users/cmbarton/grass_dev/grass_src/dist.i686-apple-darwin8.11.1/lib OBJ.i686-apple-darwin8.11.1/shpopen.o OBJ.i686-apple-darwin8.11.1/dbfopen.o &&
(cd /Users/cmbarton/grass_dev/grass_src/dist.i686-apple-darwin8.11.1/lib; ln -f -s libgrass_shape.6.3.svn.dylib /Users/cmbarton/grass_dev/grass_src/dist.i686-apple-darwin8.11.1/lib/libgrass_shape.dylib)
ld: Undefined symbols:
_SASetupDefaultHooks
/usr/bin/libtool: internal link edit command failed
make[1]: *** [/Users/cmbarton/grass_dev/grass_src/dist.i686-apple-darwin8.11.1/lib/libgrass_shape.6.3.svn.dylib] Error 1
make: *** [default] Error 2
cmb-MBP-2:~/grass_dev/grass_src cmbarton$ cd ./db/drivers/dbf
cmb-MBP-2:~/grass_dev/grass_src/db/drivers/dbf cmbarton$ make
gcc -L/Users/cmbarton/grass_dev/grass_src/dist.i686-apple-darwin8.11.1/lib -o /Users/cmbarton/grass_dev/grass_src/dist.i686-apple-darwin8.11.1/driver/db/dbf OBJ.i686-apple-darwin8.11.1/column.o OBJ.i686-apple-darwin8.11.1/cursor.o OBJ.i686-apple-darwin8.11.1/db.o OBJ.i686-apple-darwin8.11.1/dbfexe.o OBJ.i686-apple-darwin8.11.1/describe.o OBJ.i686-apple-darwin8.11.1/driver.o OBJ.i686-apple-darwin8.11.1/error.o OBJ.i686-apple-darwin8.11.1/execute.o OBJ.i686-apple-darwin8.11.1/fetch.o OBJ.i686-apple-darwin8.11.1/listtab.o OBJ.i686-apple-darwin8.11.1/main.o OBJ.i686-apple-darwin8.11.1/select.o OBJ.i686-apple-darwin8.11.1/str.o OBJ.i686-apple-darwin8.11.1/table.o OBJ.i686-apple-darwin8.11.1/create_table.o -lgrass_dbmidriver -lgrass_dbmibase -lgrass_gis -lgrass_datetime -lz -lgrass_dbstubs -lgrass_dbmibase -lgrass_gis -lgrass_datetime -lz -lgrass_gis -lgrass_datetime -lz -lgrass_gis -lgrass_datetime -lz -lgrass_dbmibase -lgrass_gis -lgrass_datetime -lz -lgrass_sqlp -lgrass_shape -lgrass_dbstubs -lgrass_dbmibase -lgrass_gis -lgrass_datetime -lz -lgrass_gis -lgrass_datetime -lz -lgrass_gis -lgrass_datetime -lz -lgrass_datetime -L/Library/Frameworks/GDAL.framework/Versions/1.5/unix/lib -lgdal -lz
/usr/bin/ld: can’t locate file for: -lgrass_shape
collect2: ld returned 1 exit status
make: *** [/Users/cmbarton/grass_dev/grass_src/dist.i686-apple-darwin8.11.1/driver/db/dbf] Error 1
cmb-MBP-2:~/grass_dev/grass_src cmbarton$ cd ./gui/wxpython/vdigit
cmb-MBP-2:~/grass_dev/grass_src/gui/wxpython/vdigit cmbarton$ make
cc -dynamiclib -compatibility_version 6.3 -current_version 6.3 -install_name /Applications/Grass/GRASS-6.3.app/Contents/MacOS/lib/libgrass6_wxvdigit.dylib -o OBJ.i686-apple-darwin8.11.1/_grass6_wxvdigit.dylib -L/Users/cmbarton/grass_dev/grass_src/dist.i686-apple-darwin8.11.1/lib OBJ.i686-apple-darwin8.11.1/cats.o OBJ.i686-apple-darwin8.11.1/digit.o OBJ.i686-apple-darwin8.11.1/driver.o OBJ.i686-apple-darwin8.11.1/grass6_wxvdigit_wrap.o OBJ.i686-apple-darwin8.11.1/line.o OBJ.i686-apple-darwin8.11.1/select.o OBJ.i686-apple-darwin8.11.1/vertex.o -lgrass_vect -lgrass_dbmibase -lgrass_gis -lgrass_datetime -lz -lgrass_dbmiclient -lgrass_dbmibase -lgrass_gis -lgrass_datetime -lz -lgrass_gis -lgrass_datetime -lz -lgrass_dgl -lgrass_dig2 -lgrass_gis -lgrass_datetime -lz -lgrass_rtree -lgrass_gis -lgrass_datetime -lz -lgrass_linkm -lgrass_rtree -lgrass_dig2 -lgrass_gis -lgrass_datetime -lz -lgrass_rtree -lgrass_dgl -lgrass_rtree -lgrass_linkm -lgrass_dbmiclient -lgrass_dbmibase -lgrass_gis -lgrass_datetime -lz -lgrass_gis -lgrass_datetime -lz -lgrass_dbmibase -lgrass_gis -lgrass_datetime -lz -L/Library/Frameworks/GDAL.framework/Versions/1.5/unix/lib -lgdal -lgrass_gis -lgrass_datetime -lz -L/Library/Frameworks/GDAL.framework/Versions/1.5/unix/lib -lgdal -lgrass_vedit -lgrass_gis -lgrass_datetime -lz -lgrass_vect -lgrass_dbmibase -lgrass_gis -lgrass_datetime -lz -lgrass_dbmiclient -lgrass_dbmibase -lgrass_gis -lgrass_datetime -lz -lgrass_gis -lgrass_datetime -lz -lgrass_dgl -lgrass_dig2 -lgrass_gis -lgrass_datetime -lz -lgrass_rtree -lgrass_gis -lgrass_datetime -lz -lgrass_linkm -lgrass_rtree -L/usr/local/lib/wxPython-unicode-2.8.7.1/lib -framework IOKit -framework Carbon -framework Cocoa -framework System -framework QuickTime -lwx_macud-2.8 -L/Library/Frameworks/Python.framework/Versions/2.5/lib/python2.5/config -ldl -lpython2.5 -lgdi
/usr/bin/libtool: can’t locate file for: -lgdi
/usr/bin/libtool: file: -lgdi is not an object file (not allowed in a library)
make: *** [OBJ.i686-apple-darwin8.11.1/_grass6_wxvdigit.dylib] Error 1
Suggestions are of course appreciated.
Thanks
Michael
On Mar 31, 2008, at 5:23 PM, William Kyngesburye wrote:
New version available.
On Mar 31, 2008, at 6:34 PM, Michael Barton wrote:
OK. Thanks for checking
Michael
On 3/31/08 3:52 PM, “William Kyngesburye” <kyngchaos@kyngchaos.com>
wrote:Is that configuring for GRASS? Look in config.log to find a more
useful reason why it couldn’t find tiffio.h.Oh, wait, it’s really not there. Crap! I was reorgranizing my Xcode
project and left the Tiger tiff headers private, though I did get the
Leopard tiff headers right.Stay tuned for an update…
On Mar 31, 2008, at 5:34 PM, Michael Barton wrote:
William,
I just updated to your current frameworks (any chance you can put a
date on each of these so that I know which ones I need to update?).When I tried a ./configure, I got an error about missing tiff files.
checking whether to use TIFF… yeschecking for location of TIFF
includes… /Library/Frameworks/UnixImageIO.framework/unix/
includechecking for tiffio.h… noconfigure: error: *** Unable to
locate TIFF includes.cmb-MBP-2:~/grass_dev/grass_src cmbarton$
Michael
William Kyngesburye <kyngchaosatkyngchaosdotcom>
http://www.kyngchaos.com/The equator is so long, it could encircle the earth completely once.
