[GRASS-dev] failure to compile v.class on Mac OS X
I just tried to compile GRASS from SVN trunk. v.class didn’t compile, so I went to the v.class folder and ran make from there. Here is the error.
Did I miss a step or does something need to be changed in v.class?
Michael
Errors in:
/Users/cmbarton/grass_dev/grass_src/gui/wxpython/vdigit
/Users/cmbarton/grass_dev/grass_src/vector/v.class
In case of errors please change into the directory with error and run ‘make’.
If you get multiple errors, you need to deal with them in the order they
appear in the error log. If you get an error building a library, you will
also get errors from anything which uses the library.
Finished compilation: Sun Feb 24 09:53:30 MST 2008
make: *** [default] Error 1
cmb-MBP-2:~/grass_dev/grass_src cmbarton$ cd vector
cmb-MBP-2:~/grass_dev/grass_src/vector cmbarton$ cd v.class
cmb-MBP-2:~/grass_dev/grass_src/vector/v.class cmbarton$ make
make: *** No rule to make target /Users/cmbarton/grass_dev/grass_src/dist.i686-apple-darwin8.11.1/lib/libgrass_arraystats.dylib', needed by /Users/cmbarton/grass_dev/grass_src/dist.i686-apple-darwin8.11.1/bin/v.class’. Stop.
C. Michael Barton, Professor of Anthropology
Director of Graduate Studies
Arizona State University
Phone: 480-965-6262
Fax: 480-965-7671
2008/2/24, Michael Barton <michael.barton@asu.edu>:
I just tried to compile GRASS from SVN trunk. v.class didn't compile, so I
You need to compile manually arraystatslib first
cd lib/arraystats
make
BTW: maybe Makefiles could be updated to compile
arraystatslib/v.class/d.thematic.area by default
Martin
Errors in:
'make'.
make
`/Users/cmbarton/grass_dev/grass_src/dist.i686-apple-darwin8.11.1/lib/libgrass_arraystats.dylib',
needed by
`/Users/cmbarton/grass_dev/grass_src/dist.i686-apple-darwin8.11.1/bin/v.class'.
Stop.
____________________
Phone: 480-965-6262
Fax: 480-965-7671
grass-dev mailing list
grass-dev@lists.osgeo.org
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa *
On Sun, February 24, 2008 18:17, Martin Landa wrote:
so I
cd lib/arraystats
make
Maybe a little testing first ? But no strong opinion either way.
Moritz
