How does this work with d.barscale or d.text.
If a font isn't specified and GRASS_FONT is NOT set, it defaults to Romans.
If a font isn't specified and GRASS_FONT IS set, it defaults to GRASS_FONT.
If a font IS set, this overrides the other two.
Also, I forgot to reiterate that d.rast.nums only does Romans and does not
respond to GRASS_FONT.
Finally, helvetica is a very nice font for this stuff. How can ps.map
default to helvetica, however? Is it likely to be present on all systems?
What happens if it's missing?
Michael
On 4/29/07 7:41 PM, "Hamish" <hamish_nospam@yahoo.com> wrote:
Michael Barton wrote:
Further testing and looks like d.text DOES respect GRASS_FONT settings
This leaves only d.label
d.labels is only a conduit. It works using the font given in labels file
and is not subject to local override. Choose the font you want at the
v.label step.
I guess we could change it to look the other way on that if the labels
file is using the default, "font: standard".
currently do_labels.c has:
#define STANDARD_FONT "romans"
if (sscanf (text, "%*s %s", font) != 1
|| !strcmp (font, "standard"))
strcpy (font, STANDARD_FONT);
we could change that hardcoded "romans", but it needs to be done
explicitly as other previous labels may have changed the font to
something specific already. (different labels in the same file can
use different fonts) How to do *string = {G|R}_get_current_font();
rather than just trusting the current state?
FWIW, ps.map defaults to Helvetica for the standard font.
Hamish
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
