[GRASS-dev] figuring out fonts - part 2
It is a good thing that GRASS has a set of fonts that can be guaranteed to be present, regardless of the system. These are the venerable stroke fonts. But these fonts are ugly and hard to read. Romans just doesn’t stand out well in a scale or legend, for example, unless against a white background and even then it is not clear at a distance for presentations.
So here is a question. Can GRASS ship with a better set of fonts? Can it come with a minimal TrueType set, for example, that could be guaranteed present regardless of the system? Or is this technically not realistically feasible?
Michael
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
But these fonts are ugly and hard to read. Romans just doesn¹t stand out
feasible?
Support for TrueType fonts requires the FreeType library, which is
currently an optional dependency.
That aside, most people will already have the Luxi font from the X.org
packages.
There are some Free/Libre TT fonts out there, of which the most
remarkable is Bitstream Vera. Any of those could be distributed within
GRASS. That would cover the FreeType lib case. One of the lucidas may
be all right as X or t1.
Is stroke font the minimal font support in GRASS? Anything default
between stroke and TT?
Daniel.
> feasible?
packages.
grass-dev mailing list
grass-dev@grass.itc.it
-- Daniel Calvelo Aros
I don't think that we should be bundling fonts which most users will
already have (Luxi and Vera are both pretty common).
The default font is the "romans" stroke font. The stroke fonts will
always be available; TrueType fonts can only be used if GRASS was
built with FreeType support.
