[GRASS-dev] file input for r.reclass etc
Hamish,
Perhaps I misunderstood, but I read a recent post of yours to suggest that ‘file=’ arguments had been added to r.reclass and r.recode. However, I just recompiled from a cvs update and I don’t see them. Did I miss something?
Michael
Director of Graduate Studies
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
'file=' arguments had been added to r.reclass and r.recode. However, I just
recompiled from a cvs update and I don't see them. Did I miss something?
AFAICT, this was discussed but hasn't actually been added yet.
I'll look into it.
I'll look into it.
I've added a rules= option to r.reclass, although it hasn't been
tested yet.
Thanks, I'll try to recompile and take a look tonight.
Michael
I'll look into it.
tested yet.
Center for Social Dynamics and Complexity
phone: 480-965-6213
fax: 480-965-7671
> I'll look into it.
tested yet.
Also for r.recode.
Glynn,
I recompiled all of GRASS (after a make distclean) just before you committed
your change to r.recode. Then I just updated and compiled r.recode, without
recompiling all the rest. Is this a problem? Do I need to recompile the
whole enchilada again?
Michael
I'll look into it.
tested yet.
Also for r.recode.
phone: 480-965-6213
fax: 480-965-7671
No.
You don't need to compile from scratch if the only files which have
changed are the source and header files in the module's directory. The
Makefile will notice that those have changed and re-compile what's
required (if any header file in the directory changes, it will
re-compile all object files).
You only need to force re-compilation (with "make clean") if there is
a change to a dependency which isn't listed as such in the module's
Makefile. This essentially means a change to the project-wide header
files, the Makefile fragments in include/Make, the configure script or
the libraries.
If a library is modified, you can just run "make" on the library's
directory, then on the directories of the modules which use it. The
modules will be re-linked if any of the libraries which they use have
changed. Running "make" from the top-level directory will handle all
of this (re-compiling libraries and re-linking whatever uses them),
without re-compiling or re-linking anything unnecessarily.
OTOH, If there are changes to project-wide header files or the
Makefile fragments, you really need to run "make clean" first, as
there is no record of whether a file depends upon any of these.
Similarly, if the configure script changes, you need to run "make
distclean" then re-run configure.
