This is my last report of the GSoC project. I would like to thank Rashad and Massimo, my mentors. Brief Description My project focussed on the development of web based GUI for the Grass “WebGrass” where people can use Grass modules on their data through a web browser without actually installing GRASS. GRASS is running on a server. The user interface is built using wt web toolkit. The state of the project before my GSoC Was not implemented but a proof of concept was there. The addition that your project brought to the software A working webapp. People can use data from their system and apply different modules and get output. A Web based UI like GRASS and modules implementation. Whole “WebGrass” is a very big project for one gsoc and we try to implement as much as possible. Things implemented- - Location and Mapset wizard - UI of the modules - Modules implementation like desktop grass (command line output also) - Authorization of the user - Input/output/processing of raster data - display of raster data - Input/output/processing of vector data From this project, a official start of “WebGrass” is done and I hope it will be useful for the people. This has been a very interesting and learning experience. I learned a lot from my mentors. I hope this project keeps on growing and will continue to contribute to this project. Links- Github - https://github.com/mayank33/webgrass/commits/gsoc2016 https://github.com/mayank33/webgrass/commits/auth Project Page - https://trac.osgeo.org/grass/wiki/GSoC/2016/WebGrass Images- first page second page Module UI Mayank Agrawal Lab for Spatial Informatics IIIT Hyderabad India |
Hi Mayank,
thanks for the final report. It looks very promising. Can you please gather your reports and put them on the wiki page as it was done in the previous years? (Last one is from week 2.) Mailing list is a good archive but it is hard to go through all of them.
Also, I was not able to find the current instructions how to run it. Did I missed them?
Vaclav
Brief Description
Things implemented-
- UI of the modules
Links-
Images-
first page
second page
Module UI
Mayank Agrawal
IIIT Hyderabad
India
grass-dev mailing list
grass-dev@lists.osgeo.org
Updated the Wiki - https://trac.osgeo.org/grass/wiki/GSoC/2016/WebGrass
Here is the Readme - https://github.com/rashadkm/webgrass/blob/master/README
On Tue, Aug 16, 2016 7:39 AM, Vaclav Petras wenzeslaus@gmail.com wrote:
Hi Mayank,
Vaclav
On Mon, Aug 15, 2016 at 8:10 PM, Mayank Agrawal <mayankagrawal333@gmail.com> wrote:
Brief Description
Things implemented-
- UI of the modules
Links-
Images-
first page
second page
Module UI
Mayank Agrawal
IIIT Hyderabad
India
Thanks!
On Tue, Aug 16, 2016 at 3:28 AM, Mayank Agrawal <mayankagrawal333@gmail.com>
I suggest merging README and README.md.
I got a clean compile on Ubuntu 16.10 following readme instruction.
yann@yann-ok:~/dev/webgrass$ mkdir build
yann@yann-ok:~/dev/webgrass$ cd build
yann@yann-ok:~/dev/webgrass/build$ cmake ..
-- The C compiler identification is GNU 6.1.1
-- The CXX compiler identification is GNU 6.1.1
-- Check for working C compiler: /usr/bin/cc
-- Check for working C compiler: /usr/bin/cc -- works
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Detecting C compile features
-- Detecting C compile features - done
-- Check for working CXX compiler: /usr/bin/c++
-- Check for working CXX compiler: /usr/bin/c++ -- works
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Detecting CXX compile features
-- Detecting CXX compile features - done
-- Found the Wt libraries at /usr/lib/libwthttp.so;/usr/lib/libwt.so
-- Found the Wt headers at /usr/include
-- Found the Wt debug libraries at /usr/lib/libwthttp.so;/usr/lib/libwt.so
-- Found the Wt debug headers at /usr/include
-- GRASS_DATA_DIR=/home/yann/grassdata
-- Configuring done
-- Generating done
-- Build files have been written to: /home/yann/dev/webgrass/build
yann@yann-ok:~/dev/webgrass/build$ cd ..
yann@yann-ok:~/dev/webgrass/build$ make
Scanning dependencies of target wgrass.wt
[ 8%] Building CXX object CMakeFiles/wgrass.wt.dir/src/MainUI.cpp.o
[ 16%] Building CXX object CMakeFiles/wgrass.wt.dir/src/WGApplication.cpp.o
[ 25%] Building CXX object CMakeFiles/wgrass.wt.dir/src/main.cpp.o
[ 33%] Building CXX object CMakeFiles/wgrass.wt.dir/src/LayerManager.cpp.o
[ 41%] Building CXX object CMakeFiles/wgrass.wt.dir/src/Display.cpp.o
[ 50%] Building CXX object CMakeFiles/wgrass.wt.dir/src/Toolbar.cpp.o
[ 58%] Building CXX object CMakeFiles/wgrass.wt.dir/src/Startup.cpp.o
[ 66%] Building CXX object CMakeFiles/wgrass.wt.dir/src/Module.cpp.o
[ 75%] Building CXX object CMakeFiles/wgrass.wt.dir/src/Parameter_text.cpp.o
[ 83%] Building CXX object CMakeFiles/wgrass.wt.dir/src/Parameter.cpp.o
[ 91%] Building CXX object CMakeFiles/wgrass.wt.dir/src/Authentication.cpp.o
[100%] Linking CXX executable wgrass.wt
[100%] Built target wgrass.wt
Whole "WebGrass" is a very big project for one gsoc and we try to implement as
much as possible.
Things implemented- * Location and Mapset wizard
* UI of the modules
* Modules implementation like desktop grass (command line output also)
* Authorization of the user
* Input/output/processing of raster data
* display of raster data
* Input/output/processing of vector dataFrom this project, a official start of "WebGrass" is done and I hope it will be
Links - Github - https://github.com/mayank33/webgrass/commits/gsoc2016 https://github.com/mayank33/webgrass/commits/auth
Images- first page
second page
Module UIMayank Agrawal Lab for Spatial Informatics IIIT Hyderabad India
Yann Chemin
Address: 3 Toul Melin, 56400 Plumergat
Mobile: +33 (0)7 83 85 52 34
Maybe not the right place to say, but the GRASS GIS data directory is not editable, so cannot change to another GRASSDATA directory name.
much as possible.
* UI of the modules
Images- first page
second page
Yann Chemin
Hi Mayank,
Thanks for WebGRASS! I am glad we can test it and thanks also for fixing the compilation issue so fast!
For me it would be absolutely OK that www-users cannot browse the whole server for GRASS DBs. And that all WebGRASS users are forced to work in one DB might be almost a pluss - from the administrators perspective ;-).
What I really like about WebGRASS is the simplicity of installing it. No long configuration and settings to be changed many places. Fast compile and It runs!
A clear drawback however is the Google based authentication, which seems to be the only available authentication method at the moment. Esp. for internal server deployment that does not feel right. Se also: https://github.com/rashadkm/webgrass/issues/19
Another question is: does WebGRASS currently only allow for a single connection at a time?
I opened one login page in one browser, and then tried to access WebGRASS in parallel from another browser, but I got a Connection Refused error...
Is that intentional or a known limitation of the chosen approach? The main aim of the web-UI is to give several users easy-access to GRASS on a server, isn`t it?
Or is the concept that each user should start his/her WebGRASS session (WebGRASS does not require root permissions to start the server process)? Would not that lead to possible issues with port conflicts?
Stefan
-----Original Message-----
From: grass-dev [mailto:grass-dev-bounces@lists.osgeo.org] On Behalf Of Yann
Sent: 16. august 2016 18:46
To: grass-dev@lists.osgeo.org
Subject: Re: [GRASS-dev] Final Report
* UI of the modules
Images- first page
second page
Yann Chemin
This is what was decided but can be implemented(editable option) in future
-DGRASS_DATA_DIR can be used in the cmake for defining the directory
much as possible.
- UI of the modules
Images- first page
second page
Module UI
Yann Chemin
